[GRASS-user] Multiple errors building Grass 7.7svn
Patton, Eric (NRCan/RNCan)
eric.patton at canada.ca
Wed May 22 06:32:07 PDT 2019
Hi Markus,
I noted your new installation instructions for the git repo and have used those.
The first error in error.log occurs in /usr/local/grass/lib/proj:
test -d OBJ.x86_64-pc-linux-gnu || mkdir -p OBJ.x86_64-pc-linux-gnu
gcc -g -O2 -fPIC -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/include -DPACKAGE=\""grasslibs"\" -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -DRELDIR=\"lib/proj\" -o OBJ.x86_64-pc-linux-gnu/convert.o -c convert.c
gcc -g -O2 -fPIC -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/include -DPACKAGE=\""grasslibs"\" -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -DRELDIR=\"lib/proj\" -o OBJ.x86_64-pc-linux-gnu/datum.o -c datum.c
gcc -g -O2 -fPIC -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/include -DPACKAGE=\""grasslibs"\" -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -DRELDIR=\"lib/proj\" -o OBJ.x86_64-pc-linux-gnu/do_proj.o -c do_proj.c
gcc -g -O2 -fPIC -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/include -DPACKAGE=\""grasslibs"\" -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -I/usr/local/grass/dist.x86_64-pc-linux-gnu/include -DRELDIR=\"lib/proj\" -o OBJ.x86_64-pc-linux-gnu/ellipse.o -c ellipse.c
do_proj.c: In function ‘GPJ_init_transform’:
do_proj.c:136:6: error: expected ‘}’ before ‘else’
else {
do_proj.c: At top level:
do_proj.c:160:5: error: expected identifier or ‘(’ before ‘if’
if (info_trans->pj == NULL)
do_proj.c:162:5: error: expected identifier or ‘(’ before ‘if’
if (info_trans->pj == NULL) {
do_proj.c:167:15: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘->’ token
info_trans->meters = 1.;
do_proj.c:168:15: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘->’ token
info_trans->zone = 0;
do_proj.c:169:23: error: expected ‘)’ before ‘->’ token
sprintf(info_trans->proj, "pipeline");
do_proj.c:180:5: error: expected identifier or ‘(’ before ‘return’
return 1;
do_proj.c:181:1: error: expected identifier or ‘(’ before ‘}’ token
../../include/Make/Compile.make:32: recipe for target 'OBJ.x86_64-pc-linux-gnu/do_proj.o' failed
make: *** [OBJ.x86_64-pc-linux-gnu/do_proj.o] Error 1
make: *** Waiting for unfinished jobs....
Thanks,
~ Eric.
-----Original Message-----
Sent: May 21, 2019 16:49
To: Patton, Eric (NRCan/RNCan) <eric.patton at canada.ca>
Cc: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Multiple errors building Grass 7.7svn
Hi Eric,
On Tue, May 21, 2019 at 6:00 PM Patton, Eric (NRCan/RNCan) <eric.patton at canada.ca> wrote:
> I was running Grass 7.7svn (trunk) fine last week, and updated to v74509 today on Linux Mint 19.1.
We just moved to GitHub:
git clone https://github.com/OSGeo/grass.git
However, a question:
> No errors during configure, but make showed many errors of the type:
> Error: /usr/lib/gcc/x86_64-linux-gnu/7/include/xmmintrin.h:120: Syntax error at '{'
I guess that these error messages appear in the ctypes part which is
(unfortunately) "normal" and apparently not an issue.
> There’s far too many errors to list here, but the result of it is that 221 grass modules fail to build.
Which is the first one listed in
error.log
Can you then cd into that directory, run "make" therein and report the error?
Markus
