[GRASS-user] Error launching GUI in Grass 7.8.1
Alessandro Sebastiani
alessandro.sebastiani at uniroma1.it
Sat Nov 16 00:22:29 PST 2019
Thank you for your help, everything's fixed now and i've learned some very
interesting stuff!
Il giorno ven 15 nov 2019 alle ore 21:36 Helmut Kudrnovsky <hellik at web.de>
ha scritto:
> Alessandro Sebastiani wrote
> > Hello to evenyone,
> > i have exactly the same problem that Eric Patton had. This morning
> > suddenly
> > I got the same error message. I read the conversation and kind understood
> > that there is a file in grass78 that should be edited in order to fix the
> > error, however i did not notice where exactly this file is and how should
> > I
> > edit it. Additionally, it only happened on my GRASS GIS installation for
> > Ubuntu in virtual machine, while the one on windows (Grass7.6) is still
> > working. Any suggestions? thank you,
> see
> https://github.com/OSGeo/grass/commit/b7fb30a1da066e8864c8e36c5d55a93402e29dd0
> for the needed edits.
> the file to change is in your GRASS installation:
> grass78\gui\wxpython\gui_core\wrap.py
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
________________________________________________________
Le informazioni
contenute in questo messaggio di posta elettronica sono strettamente
riservate e indirizzate esclusivamente al destinatario. Si prega di non
leggere, fare copia, inoltrare a terzi o conservare tale messaggio se non
si è il legittimo destinatario dello stesso. Qualora tale messaggio sia
stato ricevuto per errore, si prega di restituirlo al mittente e di
cancellarlo permanentemente dal proprio computer.
The information
contained in this e mail message is strictly confidential and intended for
the use of the addressee only. If you are not the intended recipient,
please do not read, copy, forward or store it on your computer. If you have
received the message in error, please forward it back to the sender and
delete it permanently from your computer system.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191116/9cd5d6e3/attachment.html>
