[GRASS-user] i.segment: band_suffix does not seem to have effect
    Stefan Blumentrath
    Stefan.Blumentrath at nina.no
    Wed Nov 20 06:09:20 PST 2019
Hi Moritz,
Thanks for the hint. Indeed, I used the default region_growing method, not mean_shift.
Maybe a warning message if band_suffix is given but not mean_shift method would avoid confusion?
Or a note in the manual (or both)...
Cheers
Stefan
Fra: Moritz Lennert <mlennert at club.worldonline.be>
Sendt: onsdag 20. november 2019 13:16
Til: Stefan Blumentrath <Stefan.Blumentrath at nina.no>; GRASS users list <grass-user at lists.osgeo.org>
Emne: Re: [GRASS-user] i.segment: band_suffix does not seem to have effect
On 20/11/19 11:19, Stefan Blumentrath wrote:
> Hi,
> I thought that if I give the band_suffix option in i.segment it
> produces bands with modified band values for all input bands. However,
> the option does not seem to have effect (no modified output bands are
> produced). Did I do or understand something wrong?
AFAIR, this option is only relevant if you use the mean shift
segmentation approach. Is that what you are doing ?
Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191120/da55ccc4/attachment-0001.html>
