[GRASS-user] Import CORDEX data in GRASS
Markus Neteler
neteler at osgeo.org
Mon Oct 21 13:39:26 PDT 2019
Hi Johannes,
On Fri, Oct 18, 2019 at 2:57 PM Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi all,
> I was wondering if anybody is also working with CORDEX data (Regionally downscaled climate data - Europe) that are provided via the ESGF platforms as netcdf files?
> I want to import such files in GRASS but first want to create a location with the projection of these data. AFAIK the data are in a rotated-pole coordinate system (https://is-enes-data.github.io/cordex_archive_specifications.pdf) which should be supported by GDAL (https://trac.osgeo.org/gdal/ticket/4285) however I am unsure in which version of gdal (here I am using 2.2.2 (Ubuntu 16LTS, GRASS76)
> I tried to use the location wizard to read the projection information from the netcdf file. However, here only a XY location (unprojected) is suggested. So how (and what) do I need to manually specify to define a Location that is able to correctly display CORDEX data? Any suggestions?
Is there anywhere a file to play with?
best
Markus
