[GRASS-user] Help; Running Grass from R - SQLite database setup
Mehrdad Varedi varedi at gmail.com
Tue Sep 3 23:13:01 PDT 2019
Hi Veronica,
I think the error should be because of the point you mentioned somehow.
When I use v.import, I can't import a vector file, although if I use
v.in.ogr, it works very well and as Micha had mentioned the sqlite.db is
created.
BTW, the version of rgrass7 on my machine is 0.1.12. Also, I tried it on
ubuntu and everything worked with no problem following the code provided by
Micha.
Thank you all,
Mehrdad
ᐧ
On Fri, Aug 30, 2019 at 5:14 AM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi,
> pls write to grass-stats list where you can get more answers. What version
> of rgrass7 are you using? The last one includes the possibility to use
> either sp or sf for vector data. When I run readVECT for example, I first
> run either use_sp() or use_sf(). Maybe that has something to do with the
> error? Just guessing...
> HTH,
> Vero
> El mié., 28 ago. 2019 a las 20:33, Micha Silver (<tsvibar at gmail.com>)
> escribió:
>> On 28/08/2019 21:12, Mehrdad Varedi wrote:
>> Hi Micha,
>> Your answer makes perfect sense. Thank you. I was expecting to get the
>> database when only I had imported raster files!
>> Anyway, when I tried to import a vector file with the following command,
>> I got an error:
>> *execGRASS("v.import", parameters=list(                 input =
>>  basename(inputWM),                 output = "WM"                 ),
>>     flags=c("overwrite")) *
>> Here is the error:
>> *In system(cmd0, intern = TRUE) :   running command 'v.import.bat
>> --interface-description' had status 1 Error in parseGRASS(cmd, legacyExec =
>> legacyExec) : v.import not parsed *
>> I traced the code and found that the parseGRASS adds the .bat extension
>> for the v.import and the lagacyExec has a TRUE value (default for Windows
>> OS)
>> FYI, I couldn't run GRASS from Rstudio unless ran the RStudio from the
>> "OSGeo4W" environment. It helps RStudio to find the functions in GRASS. (I
>> learned it from a previous post). So it works and importing the raster
>> files had no problem (I imported a virtual raster .vrt with "r.in.gdal"
>> command). Also, I processed the raster file with no problem. The problem
>> only shows up when I try to import the vector files with r.import command.
>> Any idea what is happening here?
>> No, sorry.
>> I expect others on the list with more experience with Windows
>> installations will be able to help.
>> Thanks for your help,
>> Mehrdad
>> ᐧ
>> On Wed, Aug 28, 2019 at 6:24 AM Micha Silver <tsvibar at gmail.com> wrote:
>>> On 28/08/2019 9:56, Mehrdad Varedi wrote:
>>> Hi Everyone,
>>> I used the code from Micha and managed to run grass in R and create a
>>> new dataset from R. I can't see the SQLite database in the created folders
>>> like the ones I usually get when creating new datasets from GRASS.
>>> How can I have the new SQlite database?
>>> If you import some vector you'll have the sqlite.db setup for you:
>>> (Following the example from before)
>>> > input_vect = "Israel_border.gpkg"
>>> > grass_vect = "isr_border"
>>> > execGRASS("v.import", input=input_vect, output=grass_vect, flags="o")
>>> Over-riding projection check
>>> Check if OGR layer <Israel_border> contains polygons...
>>>  100%
>>> Creating attribute table for layer <Israel_border>...
>>> Default driver / database set to:
>>> driver: sqlite
>>> database: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
>>> Importing 1 features (OGR layer <Israel_border>)...
>>>  100%
>>> Then in a separate terminal:
>>> micha at TP480:~$ ll /tmp/tmp_location/tmp_mapset/sqlite/
>>> total 20
>>> drwxr-xr-x 2 micha micha  4096 Aug 28 13:19 ./
>>> drwxr-xr-x 6 micha micha  4096 Aug 28 13:19 ../
>>> -rw-r--r-- 1 micha micha 12288 Aug 28 13:19 sqlite.db
>>> Thanks for your help.
>>> On Sun, Apr 28, 2019 at 10:55 AM Micha Silver <tsvibar at gmail.com> wrote:
>>>> Maybe this will help:
>>>> (You must have GRASS installed, of course)
>>>> # Parameters for the GRASS installation and temporary GRASS mapset
>>>> GISBase = "/usr/lib/grass76"
>>>> # Set these as you like
>>>> GISDbase = "/tmp"
>>>> Location = "tmp_location"
>>>> Mapset = "tmp_mapset"
>>>> georef = "EPSG:2039"
>>>> mapset_path = file.path(GISDbase, Location, Mapset)
>>>> # Now run the 'grass' command within R and
>>>> # use the -c and -e flags to create the temp mapset, then exit
>>>> setup_grass_cmd = paste("grass", "-c", georef, "-e", mapset_path)
>>>> system(setup_grass_cmd)
>>>> # Load the R grass interface and initialize GRASS within R,
>>>> # using the temporary mapset from above
>>>> library(rgrass7)
>>>> initGRASS(home=tempdir(),
>>>>           gisBase = GISBase,
>>>>           gisDbase = GISDbase,
>>>>           location = Location,
>>>>           mapset = Mapset,
>>>>           remove_GISRC = TRUE)
>>>> # Try some GRASS commands
>>>> input_tif = "isrlat12.tif"
>>>> grass_rast = "isrlat12"
>>>> execGRASS("r.in.gdal",  flags = c("o","overwrite"),
>>>>           input = input_tif,
>>>>           output = grass_rast)
>>>> execGRASS("g.region", flags="p", raster = grass_rast)
>>>> I did not add a command to remove the temporary mapset.  Something like:
>>>> unlink(file.path(GISDbase, Location), recusive = TRUE) might be
>>>> necessary
>>>> Micha Silver
>>>> Ben Gurion Univ.
>>>> Sde Boker, Remote Sensing Lab
>>>> cell: +972-523-665918
>>> Mehrdad Varedi
>>> ᐧ
>>> Micha Silver
>>> Ben Gurion Univ.
>> Mehrdad Varedi
>> Micha Silver
>> Ben Gurion Univ.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
Mehrdad Varedi
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190904/fd3cfdc4/attachment.html>
