[GRASS-user] WinGRASS addons partly back
Helmut Kudrnovsky
hellik at web.de
Wed Sep 4 14:35:07 PDT 2019
SBL wrote
> Hi Helmut,
> Did you set the computational region properly?
> Import of data outside the current region is only supported in lat/lon
> locations...
> v.in.pygbif -o output=poa_pratensis taxa="Poa pratensis" rank=species
> Gave me ~ 11k records for Norway and ~58 k records if I move the region
> 2000k towards south...
-PROJ_INFO-------------------------------------------------
datum : wgs84
ellps : wgs84
proj : ll
no_defs : defined
towgs84 : 0.000,0.000,0.000
-PROJ_EPSG-------------------------------------------------
epsg : 4326
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
g.region -p vector=ne_110m_admin_0_countries_germany at gbif
projection: 3 (Längen- und Breitengrad)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 54:58:59.174951N
south: 47:18:08.955713N
west: 5:59:19.169068E
east: 15:01:01.185182E
nsres: 0:57:36.277405
ewres: 1:00:11.335124
rows: 8
cols: 9
cells: 72
v.in.pygbif -o output=poa_pratensis taxa=Poa pratensis rank=species
Found 145951 occurrences for taxon Poa pratensis...
ok, it seems it was a region issue; addon works as expected.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
