[GRASS-user] WinGRASS addons partly back
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Wed Sep 4 14:23:21 PDT 2019
Hi Helmut,
Did you set the computational region properly?
Import of data outside the current region is only supported in lat/lon locations...
v.in.pygbif -o output=poa_pratensis taxa="Poa pratensis" rank=species
Gave me ~ 11k records for Norway and ~58 k records if I move the region 2000k towards south...
Cheers
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Helmut Kudrnovsky
Sent: onsdag 4. september 2019 22:11
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] WinGRASS addons partly back
>Of the add-ons I need, only v.strds.stats and v.in.pygbif show problems
>in
Windows.
tested winGRASS addon v.in.pygbif like mentioned in https://lists.osgeo.org/pipermail/grass-user/2019-September/080733.html
the addon is starting, though
v.in.pygbif -o output=test8 taxa=Fagus sylvatica, Poa pratensis rank=species continent=europe Found 0 occurrences for taxon Fagus sylvatica...
Found 0 occurrences for taxon Poa pratensis...
a bit strange, as doing it with GBIF plugin in QGIS 3.8 (based upon the same pygibif python library as v.in.pygbif), I get ~48000 entries for Poa pratensis just for Germany.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
