[GRASS-user] make fails to find Platform.make
Luís Moreira de Sousa
luis.de.sousa at protonmail.ch
Thu Sep 19 02:06:35 PDT 2019
Hi all,
I am compiling GRASS 7.6 in an HPC cluster running Scientific Linux. make is failing to find the folder or file ../../include/Make/Platform.make, I don't recall seeing this before.
This is the configuration command:
./configure \
-prefix=/home/WUR/duque004/grass/ \
--enable-64bit --with-fftw-includes=/cm/shared/apps/fftw/openmpi/gcc/64/3.3.7/include/ \
--with-freetype-includes=/home/WUR/duque004/grass/freetypes/freetype-2.9.1/include/ \
--with-postgres=yes \
--with-netcdf --with-geos --with-blas --with-lapack
And its output:
GRASS is now configured for: x86_64-pc-linux-gnu
Source directory: /home/WUR/duque004/grass/grass-7.6.0
Build directory: /home/WUR/duque004/grass/grass-7.6.0
Installation directory: ${prefix}/grass-7.6.0
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
Building shared libraries: yes
OpenGL platform: X11
MacOSX application: no
MacOSX architectures:
MacOSX SDK:
BLAS support: yes
BZIP2 support: no
C++ support: yes
Cairo support: yes
DWG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GEOS support: yes
LAPACK support: yes
Large File support (LFS): yes
libLAS support: no
MySQL support: no
NetCDF support: yes
NLS support: no
ODBC support: no
OGR support: yes
OpenCL support: no
OpenGL support: yes
OpenMP support: no
PDAL support: no
PNG support: yes
POSIX thread support: no
PostgreSQL support: yes
Readline support: no
Regex support: yes
SQLite support: yes
TIFF support: yes
X11 support: yes
Zstandard support: no
using old PROJ 4 API
make then fails for about 50 modules, of all kinds. Running make individually always yields the same error:
$ cd /home/WUR/duque004/grass/grass-7.6.0/lib/gmath
$ make
../../include/Make/Vars.make:1: ../../include/Make/Platform.make: No such file or directory
../../include/Make/Shlib.make:10: warning: overriding recipe for target `/dist./lib/grass_gmath...'
../../include/Make/Stlib.make:5: warning: ignoring old recipe for target `/dist./lib/grass_gmath...'
make: *** No rule to make target `../../include/Make/Platform.make'. Stop.
$ cd /home/WUR/duque004/grass/grass-7.6.0/lib/rst/interp_float
$ make
../../../include/Make/Vars.make:1: ../../../include/Make/Platform.make: No such file or directory
../../../include/Make/Shlib.make:10: warning: overriding recipe for target `/dist./lib/grass_interpfl...'
../../../include/Make/Stlib.make:5: warning: ignoring old recipe for target `/dist./lib/grass_interpfl...'
make: *** No rule to make target `../../../include/Make/Platform.make'. Stop.
$ cd /home/WUR/duque004/grass/grass-7.6.0/raster/r.sun
$ make
Any clues on what may be causing this? Thank you.
Luís
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190919/ea2c43e9/attachment-0001.html>
