[GRASS-user] Geomorphic index for valley, using "height of the valley / width of the top of the valley"
    Valter Albino
    valteralbino at gmail.com
    Sat Apr 11 17:26:25 PDT 2020
Hi Stefan
Thanks for the answer.
I tested in GRASS, but the results are not as expected. Selected the
upstream calculation method and didn't marked any option (optional tab).
The vertical distance from stream to ridge line is not good and the crest
of the valley is not correct. I did tested with SAGA the vertical distance
from stream to ridge line along the watercourse and validated it manually
(see image bellow).
[image: imagem.png]
In GRASS, the addon says:
difference
    Name of output map of elevation difference to the target (outlet, node,
stream, divide, maximum) along watercourse. The map is of DCELL type.
distance
    Name of output map of distance to the target (outlet, node, stream,
I thought that should it be possible to select the distance and difference
from the stream to the divide (ridge line).
Well, it would be great if GRASS can do it.
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Stefan Blumentrath <Stefan.Blumentrath  nina.no> escreveu no dia sábado,
11/04/2020 à(s) 22:57:
> Hi Valter,
> please have a look at:
> https://grass.osgeo.org/grass78/manuals/addons/r.stream.distance.html
> r.stream.distance - GRASS GIS manual
> <https://grass.osgeo.org/grass78/manuals/addons/r.stream.distance.html>
> NAME r.stream.distance - Calculates distance to and elevation above
> streams and outlet. The module can work in stream mode where target are
> streams and outlets mode where targets are outlets. KEYWORDS raster,
> hydrology, stream network, watercourse distance SYNOPSIS
> grass.osgeo.org
> However, it is an addon. So it is - unfortunately - not necessarily
> straight forward to integrate it into your workflows (I understood you use
> GRASS from QGIS). At least in the processing framework you would need a
> workaround.
> Hope that helps a bit never the less.
> Cheers
> Stefan
> *Fra:* grass-user <grass-user-bounces  lists.osgeo.org> på vegne av Valter
> Albino <valteralbino  gmail.com>
> *Sendt:* lørdag 11. april 2020 23:18
> *Til:* grass-user <grass-user  lists.osgeo.org>
> *Emne:* [GRASS-user] Geomorphic index for valley, using "height of the
> Hi all
> I would like to calculate a geomorphic index for valley, using the
> following equation: height of the valley / width of the top of the valley -
> the higher the index values, the greater the notch (carve in the landscape)
> in the valley.
> I found that SAGA gives the "Vertical distance to the channel network".
> Does GRASS have a function to calculate each ot the two input?
> Thanks in advance
> Cumprimentos,
> * Valter Albino -* Geógrafo Físico, M.Sc.
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200412/0f3c229b/attachment-0001.html>
Type: image/png
Desc: não disponível
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200412/0f3c229b/attachment-0001.png>
