[GRASS-user] active fire mapping with GRASS GIS?
Vishal Mehta
vishalm1975 at gmail.com
Fri Aug 21 09:39:13 PDT 2020
Thanks Veronica!
I also found i could use FIRMS for what i was looking for: here's a
snapshot-- the derived product overlaid over a True Color Composite..
[image: image.png]
https://firms2.modaps.eosdis.nasa.gov/map/#d:2020-08-20..2020-08-21;l:noaa20-viirs,terra_crc;@-122.2,38.8,9z
On Fri, Aug 21, 2020 at 5:51 AM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi Vishal,
> What about
> https://worldview.earthdata.nasa.gov/?t=2020-08-17-T12%3A21%3A52Z ?
> With `Add layers` you can add the active fire over it
> best,
> Vero
> El vie., 21 ago. 2020 a las 0:09, Vishal Mehta (<vishalm1975 at gmail.com>)
> escribió:
>> Thanks Markus,
>> I also came across this and another resource, so part of my needs are met.
>> however, i notice that these data are derived products, where a pixel is
>> designated as having a fire based on the temperature anomaly. thi is the
>> main reason if anyone is following on the firemaps available on google maps
>> that we are getting huge polygons - basically the boundaries created around
>> any pixel with a large-ish anomaly.
>> is there a quick automation workflow possible where False Color
>> Composites of near-realtime imagery using the thermal band can be created,
>> which can be updated once a day at the click of a button; and then overlay
>> the FIRES derived datasets on top? This would allow one to visualize the
>> earth surface while also overlaying the derived product.
>> i'm imagining a workflow which automates the finding of imagery as well,
>> because that part of the workflow (going to the DAAC and finding the
>> sensors , path, row etc etc) seem as tedious as it ever was..
>> Best,
>> Vishal
>> On Thu, Aug 20, 2020 at 1:23 PM Markus Neteler <neteler at osgeo.org> wrote:
>>> Hi Vishal,
>>> On Wed, Aug 19, 2020 at 11:42 PM Vishal Mehta <vishalm1975 at gmail.com>
>>> wrote:
>>> > Hi all,
>>> > as you may have heard, there are a lot of active fires in California
>>> right now.
>>> > the nearest one is about 30-40 miles away from me. i'm wondering is
>>> there some guidance on using GRASS GIS for active fire mapping using near
>>> real time imagery? i've searched online but haven't found something yet.
>>> (i'm not looking for fire modeling)
>>> Yes, you can get NRT data from here:
>>> https://firms.modaps.eosdis.nasa.gov/active_fire/
>>> - Shapefiles
>>> - Google Earth KML
>>> - Text Files (CSV)
>>> This you may import (v.import) and visualize/analyse.
>>> Best wishes,
>>> Markus
>>> Markus Neteler, PhD
>>> https://www.mundialis.de - free data with free software
>>> https://grass.osgeo.org
>>> https://courses.neteler.org/blog
>> Vishal K. Mehta, PhD
>> Sr. Scientist
>> Stockholm Environment Institute - US
>> 133 D St Suite F
>> Davis CA 95616
>> www.sei-us.org
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
Sr. Scientist
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200821/43deebb9/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200821/43deebb9/attachment-0001.png>
