[GRASS-user] V.generalize
Markus Neteler
neteler at osgeo.org
Wed Aug 26 07:27:25 PDT 2020
On Mon, Aug 24, 2020 at 4:35 PM DAZIN Fabrice (SIRS)
<Fabrice.DAZIN at sirs-fr.com> wrote:
> Dear all,
> In the process of transforming a raster classification into a vector layer, I use among others the command V.GENERALIZE.
> v.generalize input=v_classif_ext at PERMANENT layer=1 type=area type=boundary method=reduction threshold=4 alpha=0.5 iterations=4 output=v_classif_ext_redv.generalize input=v_classif_ext_red at PERMANENT layer=1 type=area type=boundary method=sliding_averaging threshold=100 alpha=0.5 iterations=4 output=v_smooth_1
> with
> grassversion=79
> srid=2154
> And I wonder why the smoothing result is not homogeneous, even sometimes for the same polygon.
> Any idea about the reason?
Not sure about this particular "reduction" method but did you already
try with a different method?
Best regards,
Markus
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
