[GRASS-user] r.futures not working
Tom Hackbarth
txhackbarth at gmail.com
Fri Dec 11 07:01:03 PST 2020
Dear Anna,
yes I set the path right and this is the answer I get when running Rscript:
Rscript
Usage: /path/to/Rscript [--options] [-e expr [-e expr2 ...] | file] [args]
--options accepted are
--help Print usage and exit
--version Print version and exit
--verbose Print information on progress
--default-packages=list
Where 'list' is a comma-separated set
of package names, or 'NULL'
or options to R, in addition to --no-echo --no-restore, such as
--save Do save workspace at the end of the session
--no-environ Don't read the site and user environment files
--no-site-file Don't read the site-wide Rprofile
--no-init-file Don't read the user R profile
--restore Do restore previously saved objects at startup
--vanilla Combine --no-save, --no-restore, --no-site-file
--no-init-file and --no-environ
'file' may contain spaces but not shell metacharacters
Expressions (one or more '-e <expr>') may be used *instead* of 'file'
See also ?Rscript from within R
So I guess it is working properly?
Am Fr., 11. Dez. 2020 um 15:35 Uhr schrieb Anna Petrášová <
kratochanna at gmail.com>:
> Hi Tom,
> please keep the conversation on the mailing list.
> The problem in the GUI is unrelated, you can always type in the attribute
> column if it doesn't show up.
> With running Rscript I mean typing 'Rscript' into the (black) terminal and
> pressing enter. If the system can find it, it will try to run it and you
> would get a message with Rscript parameters. When you tried to run the PATH
> command, have you adjusted it with the path to your R installation?
> On Fri, Dec 11, 2020 at 6:02 AM Tom Hackbarth <txhackbarth at gmail.com>
> wrote:
>> Hi Anna,
>> I used the set PATH=%PATH%;C:\Program Files\R\R-3.5.0\bin code you
>> mentioned. It is not working. I still do not understand how to run Rscript
>> in the terminal to try out whether it has worked or not.
>> I just wonder whether it is not the r.futures model that is not working.
>> When I try to use it, I cannot select any layers for developed_column or
>> subregions_column, as you can see in the picture attached. This is the
>> first time I have encountered this problem within grass.
>> Can you maybe try if it is working on your computer? I tried it now on
>> windows, linux manjaro and mac and I get the same error.
>> Thank you so much for your support.
>> Best regards
>> Tom
>> [image: image.png]
>> Am Fr., 11. Dez. 2020 um 10:21 Uhr schrieb Tom Hackbarth <
>> txhackbarth at gmail.com>:
>>> Hi Anna,
>>> can you tell me how I can run Rscript in the terminal?
>>> Best regards
>>> Tom
>>> Am Do., 10. Dez. 2020 um 17:10 Uhr schrieb Anna Petrášová <
>>>> Hi Tom,
>>>> On Thu, Dec 10, 2020 at 4:24 AM Tom Hackbarth <txhackbarth at gmail.com>
>>>> wrote:
>>>>> Hi Anna,
>>>>> thanks for your answer.
>>>>> I reinstalled it already multiple times. I get the same error message
>>>>> every time though. I will try it on a mac tomorrow, but that is the last
>>>>> idea I have. Has there ever been a problem like this using r.futures? It's
>>>>> such a shame because I really want to use it for my Master's Thesis as it
>>>>> is capable of all the things that I need to do for it, but I cannot get
>>>>> it to work.
>>>> I am not sure why reinstalling doesn't work and I am myself on Linux
>>>> so can't test now. You can try to paste a line like this:
>>>> in the GRASS terminal (the black one), you need to change the path to R
>>>> based on your R installation. Then try to run Rscript in the terminal, just
>>>> to see if the binary can now be found. If yes, try to run
>>>> r.futures.potential. This temporarily changes the PATH variable so that
>>>> your system can find R, once you close GRASS, you need to repeat this next
>>>> you need to run it. Let us know if at least this works.
>>>> Anna
>>>>> Best regards
>>>>> Tom
>>>>> Am Mi., 9. Dez. 2020 um 15:01 Uhr schrieb Anna Petrášová <
>>>>>> On Wed, Dec 9, 2020 at 8:37 AM Tom Hackbarth <txhackbarth at gmail.com>
>>>>>> wrote:
>>>>>>> Dear grass users,
>>>>>>> I am trying to work my way through the r.futures workshop (
>>>>>>> https://grasswiki.osgeo.org/wiki/Workshop_on_urban_growth_modeling_with_FUTURES#Potential_submodel),
>>>>>>> but as soon as I get to the point of using the first r.futures module -
>>>>>>> r.futures-potential I come to a dead end.
>>>>>>> This is the message I get:
>>>>>>> ___________________________
>>>>>>> r.futures.potential input=sampling at practice1 output=potential.csv
>>>>>>> columns=devpressure_0_5_92,road_dens_perc,forest_1992_smooth_perc,dist_to_water_km,dist_to_protected_km
>>>>>>> developed_column=urban_change_clip subregions_column=counties
>>>>>>> Computing model...
>>>>>>> Traceback (most recent call last):
>>>>>>> File "C:\Users\XXXX\AppData\Roaming\GRASS7\addons/scripts
>>>>>>> /r.futures.potential.py", line 221, in <module>
>>>>>>> sys.exit(main())
>>>>>>> /r.futures.potential.py", line 192, in main
>>>>>>> p = subprocess.Popen(cmd, stdout=subprocess.PIPE,
>>>>>>> stderr=subprocess.PIPE)
>>>>>>> File "D:\Programme\apps\Python37\lib\subprocess.py", line
>>>>>>> 756, in __init__
>>>>>>> restore_signals, start_new_session)
>>>>>>> 1155, in _execute_child
>>>>>>> startupinfo)
>>>>>>> FileNotFoundError: [WinError 2] The system cannot find the file
>>>>>>> specified)
>>>>>>> _____________________________
>>>>>>> There seems to be a problem with the Python code. I also tried to
>>>>>>> work it out on linux manjaro, but I get more or less the same error message
>>>>>>> in the End.
>>>>>>> Is there anyone who can help me on this? I came not even close to
>>>>>>> repairing the error, so I am happy about any advice one can give me.
>>>>>>> Thank you in advance.
>>>>>>> Copying response from grass-web:
>>>>>> r.futures.potential calls Rscript, so the error means it can't find
>>>>>> the Rscript binary. If R is installed, I would recommend reinstalling
>>>>>> GRASS, during installation it tries to automatically look for it, so there
>>>>>> is a chance it will work then. I would recommend subscribing to grass-user
>>>>>> mailing list and ask more questions there.
>>>>>> Anna
>>>>>>> Best regards
>>>>>>> Tom
>>>>>>> _______________________________________________
>>>>>>> grass-user mailing list
>>>>>>> grass-user at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201211/b8dfa995/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201211/b8dfa995/attachment-0001.png>
