[GRASS-user] r.futures not working
    Anna Petrášová
    kratochanna at gmail.com
    Fri Dec 11 06:34:52 PST 2020
Hi Tom,
please keep the conversation on the mailing list.
The problem in the GUI is unrelated, you can always type in the attribute
column if it doesn't show up.
With running Rscript I mean typing 'Rscript' into the (black) terminal and
pressing enter. If the system can find it, it will try to run it and you
would get a message with Rscript parameters. When you tried to run the PATH
command, have you adjusted it with the path to your R installation?
On Fri, Dec 11, 2020 at 6:02 AM Tom Hackbarth <txhackbarth at gmail.com> wrote:
> Hi Anna,
> I used the set PATH=%PATH%;C:\Program Files\R\R-3.5.0\bin code you
> mentioned. It is not working. I still do not understand how to run Rscript
> in the terminal to try out whether it has worked or not.
> I just wonder whether it is not the r.futures model that is not working.
> When I try to use it, I cannot select any layers for developed_column or
> subregions_column, as you can see in the picture attached. This is the
> first time I have encountered this problem within grass.
> Can you maybe try if it is working on your computer? I tried it now on
> windows, linux manjaro and mac and I get the same error.
> Thank you so much for your support.
> Best regards
> Tom
> [image: image.png]
> Am Fr., 11. Dez. 2020 um 10:21 Uhr schrieb Tom Hackbarth <
> txhackbarth at gmail.com>:
>> Hi Anna,
>> can you tell me how I can run Rscript in the terminal?
>> Best regards
>> Tom
>> Am Do., 10. Dez. 2020 um 17:10 Uhr schrieb Anna Petrášová <
>> kratochanna at gmail.com>:
>>> Hi Tom,
>>> On Thu, Dec 10, 2020 at 4:24 AM Tom Hackbarth <txhackbarth at gmail.com>
>>> wrote:
>>>> Hi Anna,
>>>> thanks for your answer.
>>>> I reinstalled it already multiple times. I get the same error message
>>>> every time though. I will try it on a mac tomorrow, but that is the last
>>>> idea I have. Has there ever been a problem like this using r.futures? It's
>>>> such a shame because I really want to use it for my Master's Thesis as it
>>>> is capable of all the things that I need to do for it, but I cannot get
>>>> it to work.
>>> I am not sure why reinstalling doesn't work and I am myself on Linux
>>> so can't test now. You can try to paste a line like this:
>>> in the GRASS terminal (the black one), you need to change the path to R
>>> based on your R installation. Then try to run Rscript in the terminal, just
>>> to see if the binary can now be found. If yes, try to run
>>> r.futures.potential. This temporarily changes the PATH variable so that
>>> your system can find R, once you close GRASS, you need to repeat this next
>>> you need to run it. Let us know if at least this works.
>>> Anna
>>>> Best regards
>>>> Tom
>>>> Am Mi., 9. Dez. 2020 um 15:01 Uhr schrieb Anna Petrášová <
>>>>> On Wed, Dec 9, 2020 at 8:37 AM Tom Hackbarth <txhackbarth at gmail.com>
>>>>> wrote:
>>>>>> Dear grass users,
>>>>>> I am trying to work my way through the r.futures workshop (
>>>>>> https://grasswiki.osgeo.org/wiki/Workshop_on_urban_growth_modeling_with_FUTURES#Potential_submodel),
>>>>>> but as soon as I get to the point of using the first r.futures module -
>>>>>> r.futures-potential I come to a dead end.
>>>>>> This is the message I get:
>>>>>> ___________________________
>>>>>> r.futures.potential input=sampling at practice1 output=potential.csv
>>>>>> columns=devpressure_0_5_92,road_dens_perc,forest_1992_smooth_perc,dist_to_water_km,dist_to_protected_km
>>>>>> developed_column=urban_change_clip subregions_column=counties
>>>>>> Computing model...
>>>>>> Traceback (most recent call last):
>>>>>>   File "C:\Users\XXXX\AppData\Roaming\GRASS7\addons/scripts
>>>>>> /r.futures.potential.py", line 221, in <module>
>>>>>>     sys.exit(main())
>>>>>> /r.futures.potential.py", line 192, in main
>>>>>>     p = subprocess.Popen(cmd, stdout=subprocess.PIPE,
>>>>>> stderr=subprocess.PIPE)
>>>>>>   File "D:\Programme\apps\Python37\lib\subprocess.py", line
>>>>>> 756, in __init__
>>>>>>     restore_signals, start_new_session)
>>>>>> 1155, in _execute_child
>>>>>>     startupinfo)
>>>>>> FileNotFoundError: [WinError 2] The system cannot find the file
>>>>>> specified)
>>>>>> _____________________________
>>>>>> There seems to be a problem with the Python code. I also tried to
>>>>>> work it out on linux manjaro, but I get more or less the same error message
>>>>>> in the End.
>>>>>> Is there anyone who can help me on this? I came not even close to
>>>>>> repairing the error, so I am happy about any advice one can give me.
>>>>>> Thank you in advance.
>>>>>> Copying response from grass-web:
>>>>> r.futures.potential calls Rscript, so the error means it can't find
>>>>> the Rscript binary. If R is installed, I would recommend reinstalling
>>>>> GRASS, during installation it tries to automatically look for it, so there
>>>>> is a chance it will work then. I would recommend subscribing to grass-user
>>>>> mailing list and ask more questions there.
>>>>> Anna
>>>>>> Best regards
>>>>>> Tom
>>>>>> _______________________________________________
>>>>>> grass-user mailing list
>>>>>> grass-user at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201211/a563f55f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201211/a563f55f/attachment-0001.png>
