[GRASS-user] r.futures not working
Tom Hackbarth txhackbarth at gmail.com
Sat Dec 12 04:16:35 PST 2020
Hi Helmut,
I have switched to the earlier rbatch version. But I still get the same
error message running r.futures.
This is what happens when I type R or Rscript in the Shell:
*run o-help for a list of available commandsC:\>RDer Befehl "R" ist
entweder falsch geschrieben oderkonnte nicht gefunden werden.C:\>RscriptDer
Befehl "Rscript" ist entweder falsch geschrieben oderkonnte nicht gefunden
werden.*
(that means it's been typed wrong or couldn't be found).
In the Grass terminal running R or Rscript only works if I have set the
Path beforehand.
Best regards
Tom
Am Sa., 12. Dez. 2020 um 12:53 Uhr schrieb Helmut Kudrnovsky <hellik at web.de
> >It is still not working and the error message is still the same.
> install.packages(c("MuMIn", "lme4", "optparse", "rgrass7")) done?
> I got a similar error message when MuMIn wasn't installed.
> have you tried in OSGeo4W to switch to an earier rbatch version. then R
> should be added automatically to %PATH% and r.future.develop works as
> expected, see my earlier mail.
> if switched, type R and RScript into the OSGeo4W shell and report here.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201212/21a75a97/attachment.html>
