[GRASS-user] How to obtain list of all raster maps
BHARATH RAM br11 at iitbbs.ac.in
Sat Dec 12 05:18:10 PST 2020
Dear Mr. Neteler & Mr. Silver,
    Thank you both for your responses. Yes both of the methods seems to be
working.
Also, while going through some other documentation i discovered another
metho. We can output the entire data into a text file by including an
output argument in the command. (*g.list type='raster' mapset='.'
output='rasterNames.txt' )*
Problem solved... Thanks
Regards,
Bharath
Bsr
On Sat, Dec 12, 2020, 5:05 PM Micha Silver <tsvibar at gmail.com> wrote:
> You can use the grass.script module 'read_command' to save the output of
> commands. i.e.
> In [1]: import grass.script as gscript
> In [2]: rast_list = gscript.read_command('g.list', type='rast',
> mapset="shkharia").strip().split('\n')
> In [3]: type(rast_list)
> Out[4]: list
> In [5]: rast_list
> Out[6]: ['aspect_4m', 'dtm_08_4m', 'dtm_4m', 'geomorph', 'shade_4m',
> 'slope_4m']
> Typically the output will be a string (or dict), but calling split('\n')
> breaks it into a list.
> On 12/12/20 1:07 PM, BHARATH RAM wrote:
> > Hello,
> >      I have a list of raster files inside a mapset that I need to
> > interpolate to a different size. I am aware of the command *g.list
> > type='raster' mapset='.'*
> > and its equivalent python version. But the command prints the
> > filenames out on screen instead of returning it as a list (I am
> > talking wrt python API).
> > Am I missing something or is there any workaround for this?
> > Thank you.
> > Regards,
> > Bharath.
> > *Disclaimer: *This email and any files transmitted with it are
> > confidential and intended solely for the use of the individual or
> > entity to whom they are addressed. If you have received this email in
> > error please notify the system manager. This message contains
> > confidential information and is intended only for the individual
> > named. If you are not the named addressee you should not disseminate,
> > distribute or copy this e-mail. Please notify the sender immediately
> > by e-mail if you have received this e-mail by mistake and delete this
> > e-mail from your system. If you are not the intended recipient you are
> > notified that disclosing, copying, distributing or taking any action
> > in reliance on the contents of this information is strictly prohibited.
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
*Disclaimer: *This email and any files transmitted with it are confidential
and intended solely for the use of the individual or entity to whom they
are addressed. If you have received this email in error please notify the
system manager. This message contains confidential information and is
intended only for the individual named. If you are not the named addressee
you should not disseminate, distribute or copy this e-mail. Please notify
the sender immediately by e-mail if you have received this e-mail by
mistake and delete this e-mail from your system. If you are not the
intended recipient you are notified that disclosing, copying, distributing
or taking any action in reliance on the contents of this information is
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201212/b30718fb/attachment-0001.html>
