[GRASS-user] r.futures not working
Tom Hackbarth
txhackbarth at gmail.com
Sat Dec 12 08:41:43 PST 2020
Hi Helmut,
I deleted everything and downloaded it again just as you said, with the
different batchfile. I still get the same error message (only with a
different path in the error message/see below) and there is still nothing
happening if I try to run R or Rscript in the Shell (no matter if Grass is
running or not).
Computing model...
File "C:\Users\txhac\AppData\Roaming\GRASS7\addons/scripts
/r.futures.potential.py", line 221, in <module>
sys.exit(main())
/r.futures.potential.py", line 192, in main
p = subprocess.Popen(cmd, stdout=subprocess.PIPE,
stderr=subprocess.PIPE)
File "C:\OSGEO4~1\apps\Python37\lib\subprocess.py", line
756, in __init__
restore_signals, start_new_session)
1155, in _execute_child
startupinfo)
FileNotFoundError: [WinError 2] Das System kann die
angegebene Datei nicht finden
Am Sa., 12. Dez. 2020 um 15:15 Uhr schrieb Helmut Kudrnovsky <hellik at web.de
> [a hint to save message size:
> - just open a windows command console,
> - change to the relevant folder: e.g.
> C:\Users\your user>cd C:\OSGeo4W64\etc\ini
> C:\OSGeo4W64\etc\ini>
> - do dir /b
> C:\OSGeo4W64\etc\ini>dir /b
> gdal.bat
> libgeotiff.bat
> libjpeg.bat
> liblas.bat
> msvcrt.bat
> msys.bat
> proj.bat
> python-core.bat
> qt4.bat
> rbatchfiles.bat
> - mark the console output with mouse
> - copy the text into the mail]
> ok, at your computer, there seems to be some incomplete OSGeo4W
> installation
> leftovers here and there. not sure why.
> it's recommended to install OSGeo4W 64 bit into C:\OSGeo4W64, not into
> c:\Programme
> >Does it make sense to transfer this data into the OSGeo64W Folder?
> as we don't know, how (in)complete the OSGeo4W installation(s) are, I
> suggest to delete both of them and try to re-install a new attempt in
> C:\OSGeo4W64.
> then try my procedures mentioned before in previous mails.
> the content of C:\OSGeo4W64\etc\ini should be something like:
> gdal.bat
> libgeotiff.bat
> libjpeg.bat
> liblas.bat
> msvcrt.bat
> msys.bat
> proj.bat
> python-core.bat
> qt4.bat
> rbatchfiles.bat <=
> especially rbatchfiles.bat
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201212/cae8bdca/attachment.html>
