[GRASS-user] configure file for Fedora 33 and grass-7.8.5
mdwxman
mdwxman at protonmail.com
Wed Dec 23 11:35:38 PST 2020
Evidently "TIFF" corresponds to libtiff. I'll attempt to dnf install.
Michael Allen
Industrial Weather
763-777-1263
Sent with [ProtonMail](https://protonmail.com) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Wednesday, December 23, 2020 1:32 PM, mdwxman via grass-user <grass-user at lists.osgeo.org> wrote:
> Markus:
> Who knows what the configure means by "TIFF missing?" But here's the configure file and the result:
> (base) [root at godelsrevenge grass-7.8.5]# ./configure \
>> --with-cxx \
>> --with-gdal=/usr/bin/gdal-config \
>> --with-proj --with-proj-share=/usr/share/proj \
>> --with-geos \
>> --with-sqlite \
>> --with-nls \
>> --with-wxwidgets=/usr/bin/wx-config \
>> --with-fftw \
>> --with-cairo --with-cairo-ldflags=-ldfontconfig \
>> --with-freetype --with-freetype-includes=/usr/include/freetype2 \
>> --enable-largefile \
>> --without-odbc \
>> --with-blas --with-blas-includes=/usr/include/atlas-x86_64-base/ \
>> --with-lapack --with-lapack-includes=/usr/include/atlas-x86_64-base/ \
>> --with-zstd
> checking host system type... x86_64-pc-linux-gnu
> checking for gcc... gcc
> checking whether the C compiler (gcc ) works... yes
> checking whether the C compiler (gcc ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... yes
> checking for Cygwin environment... no
> checking for mingw32 environment... no
> checking for executable suffix... no
> checking for full floating-point support... yes
> checking for pwd... /usr/bin/pwd
> checking for source directory... /grass-7.8.5
> checking for build directory... /grass-7.8.5
> checking for git... /usr/bin/git
> fatal: not a git repository (or any of the parent directories): .git
> checking for MacOSX App... no
> checking for MacOSX architectures... no
> checking for MacOSX SDK... no
> checking how to build libraries... shared
> checking for additional include dirs...
> checking for additional library dirs...
> checking for a BSD compatible install... /usr/bin/install -c
> checking for flex... flex
> checking for yywrap in -lfl... no
> checking for bison... bison -y
> checking for ranlib... ranlib
> checking for ar... ar
> checking for env... env
> checking for perl... /usr/bin/perl
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for limits.h... yes
> checking for termio.h... yes
> checking for termios.h... yes
> checking for unistd.h... yes
> checking for values.h... yes
> checking for f2c.h... no
> checking for g2c.h... no
> checking for sys/ioctl.h... yes
> checking for sys/mtio.h... yes
> checking for sys/resource.h... yes
> checking for sys/time.h... yes
> checking for sys/timeb.h... yes
> checking for sys/types.h... yes
> checking for sys/utsname.h... yes
> checking for libintl.h... yes
> checking for iconv.h... yes
> checking for langinfo.h... yes
> checking whether time.h and sys/time.h may both be included... yes
> checking for off_t... yes
> checking for uid_t in sys/types.h... yes
> checking return type of signal handlers... void
> checking for ftime... yes
> checking for gethostname... yes
> checking for gettimeofday... yes
> checking for lseek... yes
> checking for nice... yes
> checking for time... yes
> checking for uname... yes
> checking for seteuid... yes
> checking for setpriority... yes
> checking for setreuid... yes
> checking for setruid... no
> checking for drand48... yes
> checking for putenv... yes
> checking for setenv... yes
> checking for nanosleep... yes
> checking whether setpgrp takes no argument... yes
> checking for long long int... yes
> checking for int64_t... yes
> checking for W11... no
> checking for X... libraries , headers
> checking for dnet_ntoa in -ldnet... no
> checking for dnet_ntoa in -ldnet_stub... no
> checking for gethostbyname... yes
> checking for connect... yes
> checking for remove... yes
> checking for shmat... yes
> checking for IceConnectionNumber in -lICE... yes
> checking for library containing cuserid... none required
> checking for asprintf... yes
> checking for atan... no
> checking for atan in -lm... yes
> checking for dlsym... no
> checking for dlsym in -ldl... yes
> checking for iconv... yes
> checking for socket... yes
> checking for location of zlib includes...
> checking for zlib.h... yes
> checking for location of zlib library...
> checking for deflate in -lz... yes
> checking whether to use bzlib... no
> checking whether to use zstd... yes
> checking for location of zstd includes...
> checking for zstd.h... yes
> checking for location of zstd library...
> checking for ZSTD_compress in -lzstd... yes
> checking for location of External PROJ includes...
> checking for proj.h... yes
> checking External PROJ major version... 6
> checking External PROJ minor version... 3
> checking External PROJ patch version... 2
> found PROJ version 6.3.2
> using new PROJ version 5+ API
> checking for location of External PROJ library...
> checking for proj_pj_info in -lproj... yes
> checking for location of External PROJ data files... /usr/share/proj
> checking whether to use regex... yes
> checking for location of regex includes...
> checking for regex.h... yes
> checking for location of regex library...
> checking for regcomp... yes
> checking whether to use Readline... no
> checking whether to use GDAL... yes
> checking for gdal-config... /usr/bin/gdal-config
> checking whether to use libLAS... no
> checking whether to use PDAL... no
> checking whether to use NetCDF... no
> checking whether to use GEOS... yes
> checking for geos-config... /usr/bin/geos-config
> checking for geos_c.h... yes
> checking for initGEOS in -lgeos_c... yes
> checking whether to use TIFF... yes
> checking for location of TIFF includes...
> checking for tiffio.h... no
> configure: error: *** Unable to locate TIFF includes.
> I hope you can see something. I've now memorized the ./configure text!! I see the next-to-last line:
> "checking for tiffio.h" and the response: "no" hmmm. I don't know what that means. Maybe you can explain it.
> Michael Allen
> Industrial Weather
> 763-777-1263
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201223/96124886/attachment-0001.html>
