[GRASS-user] configure file for Fedora 33 and grass-7.8.5
mdwxman
mdwxman at protonmail.com
Wed Dec 23 11:39:46 PST 2020
And here's what I get from the dnf install libtiff:
(base) [root at godelsrevenge ~]# dnf install libtiff
Fedora Modular 33 - x86_64 - Updates 40 kB/s | 15 kB 00:00
Fedora 33 - x86_64 - Updates 54 kB/s | 16 kB 00:00
Package libtiff-4.1.0-4.fc33.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
Could it be that the Fedora 33 gremlins have inserted a differently-named libtiff version or a different location?
Michael Allen
Industrial Weather
763-777-1263
Sent with [ProtonMail](https://protonmail.com) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Wednesday, December 23, 2020 1:35 PM, mdwxman <mdwxman at protonmail.com> wrote:
> Evidently "TIFF" corresponds to libtiff. I'll attempt to dnf install.
> Michael Allen
> Industrial Weather
> 763-777-1263
> On Wednesday, December 23, 2020 1:32 PM, mdwxman via grass-user <grass-user at lists.osgeo.org> wrote:
>> Markus:
>> Who knows what the configure means by "TIFF missing?" But here's the configure file and the result:
>> (base) [root at godelsrevenge grass-7.8.5]# ./configure \
>>> --with-cxx \
>>> --with-gdal=/usr/bin/gdal-config \
>>> --with-proj --with-proj-share=/usr/share/proj \
>>> --with-geos \
>>> --with-sqlite \
>>> --with-nls \
>>> --with-wxwidgets=/usr/bin/wx-config \
>>> --with-fftw \
>>> --with-cairo --with-cairo-ldflags=-ldfontconfig \
>>> --with-freetype --with-freetype-includes=/usr/include/freetype2 \
>>> --enable-largefile \
>>> --without-odbc \
>>> --with-blas --with-blas-includes=/usr/include/atlas-x86_64-base/ \
>>> --with-lapack --with-lapack-includes=/usr/include/atlas-x86_64-base/ \
>>> --with-zstd
>> checking host system type... x86_64-pc-linux-gnu
>> checking for gcc... gcc
>> checking whether the C compiler (gcc ) works... yes
>> checking whether the C compiler (gcc ) is a cross-compiler... no
>> checking whether we are using GNU C... yes
>> checking whether gcc accepts -g... yes
>> checking for Cygwin environment... no
>> checking for mingw32 environment... no
>> checking for executable suffix... no
>> checking for full floating-point support... yes
>> checking for pwd... /usr/bin/pwd
>> checking for source directory... /grass-7.8.5
>> checking for build directory... /grass-7.8.5
>> checking for git... /usr/bin/git
>> fatal: not a git repository (or any of the parent directories): .git
>> checking for MacOSX App... no
>> checking for MacOSX architectures... no
>> checking for MacOSX SDK... no
>> checking how to build libraries... shared
>> checking for additional include dirs...
>> checking for additional library dirs...
>> checking for a BSD compatible install... /usr/bin/install -c
>> checking for flex... flex
>> checking for yywrap in -lfl... no
>> checking for bison... bison -y
>> checking for ranlib... ranlib
>> checking for ar... ar
>> checking for env... env
>> checking for perl... /usr/bin/perl
>> checking how to run the C preprocessor... gcc -E
>> checking for ANSI C header files... yes
>> checking for limits.h... yes
>> checking for termio.h... yes
>> checking for termios.h... yes
>> checking for unistd.h... yes
>> checking for values.h... yes
>> checking for f2c.h... no
>> checking for g2c.h... no
>> checking for sys/ioctl.h... yes
>> checking for sys/mtio.h... yes
>> checking for sys/resource.h... yes
>> checking for sys/time.h... yes
>> checking for sys/timeb.h... yes
>> checking for sys/types.h... yes
>> checking for sys/utsname.h... yes
>> checking for libintl.h... yes
>> checking for iconv.h... yes
>> checking for langinfo.h... yes
>> checking whether time.h and sys/time.h may both be included... yes
>> checking for off_t... yes
>> checking for uid_t in sys/types.h... yes
>> checking return type of signal handlers... void
>> checking for ftime... yes
>> checking for gethostname... yes
>> checking for gettimeofday... yes
>> checking for lseek... yes
>> checking for nice... yes
>> checking for time... yes
>> checking for uname... yes
>> checking for seteuid... yes
>> checking for setpriority... yes
>> checking for setreuid... yes
>> checking for setruid... no
>> checking for drand48... yes
>> checking for putenv... yes
>> checking for setenv... yes
>> checking for nanosleep... yes
>> checking whether setpgrp takes no argument... yes
>> checking for long long int... yes
>> checking for int64_t... yes
>> checking for W11... no
>> checking for X... libraries , headers
>> checking for dnet_ntoa in -ldnet... no
>> checking for dnet_ntoa in -ldnet_stub... no
>> checking for gethostbyname... yes
>> checking for connect... yes
>> checking for remove... yes
>> checking for shmat... yes
>> checking for IceConnectionNumber in -lICE... yes
>> checking for library containing cuserid... none required
>> checking for asprintf... yes
>> checking for atan... no
>> checking for atan in -lm... yes
>> checking for dlsym... no
>> checking for dlsym in -ldl... yes
>> checking for iconv... yes
>> checking for socket... yes
>> checking for location of zlib includes...
>> checking for zlib.h... yes
>> checking for location of zlib library...
>> checking for deflate in -lz... yes
>> checking whether to use bzlib... no
>> checking whether to use zstd... yes
>> checking for location of zstd includes...
>> checking for zstd.h... yes
>> checking for location of zstd library...
>> checking for ZSTD_compress in -lzstd... yes
>> checking for location of External PROJ includes...
>> checking for proj.h... yes
>> checking External PROJ major version... 6
>> checking External PROJ minor version... 3
>> checking External PROJ patch version... 2
>> found PROJ version 6.3.2
>> using new PROJ version 5+ API
>> checking for location of External PROJ library...
>> checking for proj_pj_info in -lproj... yes
>> checking for location of External PROJ data files... /usr/share/proj
>> checking whether to use regex... yes
>> checking for location of regex includes...
>> checking for regex.h... yes
>> checking for location of regex library...
>> checking for regcomp... yes
>> checking whether to use Readline... no
>> checking whether to use GDAL... yes
>> checking for gdal-config... /usr/bin/gdal-config
>> checking whether to use libLAS... no
>> checking whether to use PDAL... no
>> checking whether to use NetCDF... no
>> checking whether to use GEOS... yes
>> checking for geos-config... /usr/bin/geos-config
>> checking for geos_c.h... yes
>> checking for initGEOS in -lgeos_c... yes
>> checking whether to use TIFF... yes
>> checking for location of TIFF includes...
>> checking for tiffio.h... no
>> configure: error: *** Unable to locate TIFF includes.
>> I hope you can see something. I've now memorized the ./configure text!! I see the next-to-last line:
>> "checking for tiffio.h" and the response: "no" hmmm. I don't know what that means. Maybe you can explain it.
>> Michael Allen
>> Industrial Weather
>> 763-777-1263
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201223/986d5009/attachment.html>
