[GRASS-user] configure file for Fedora 33 and grass-7.8.5
mdwxman mdwxman at protonmail.com
Wed Dec 23 13:14:40 PST 2020
Yeah, I noticed that. Libtiff-devel now installed.
Michael Allen
Industrial Weather
763-777-1263
Sent with [ProtonMail](https://protonmail.com) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Wednesday, December 23, 2020 2:08 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi
> You need to install the development package as well which includes the header .h files:
> libtiff-devel
> Markus
> mdwxman via grass-user <grass-user at lists.osgeo.org> schrieb am Mi., 23. Dez. 2020, 20:39:
>> And here's what I get from the dnf install libtiff:
>> (base) [root at godelsrevenge ~]# dnf install libtiff
>> Fedora Modular 33 - x86_64 - Updates 40 kB/s | 15 kB 00:00
>> Fedora 33 - x86_64 - Updates 54 kB/s | 16 kB 00:00
>> Package libtiff-4.1.0-4.fc33.x86_64 is already installed.
>> Dependencies resolved.
>> Nothing to do.
>> Complete!
>> Could it be that the Fedora 33 gremlins have inserted a differently-named libtiff version or a different location?
>> Michael Allen
>> Industrial Weather
>> 763-777-1263
>> On Wednesday, December 23, 2020 1:35 PM, mdwxman <mdwxman at protonmail.com> wrote:
>>> Evidently "TIFF" corresponds to libtiff. I'll attempt to dnf install.
>>> Michael Allen
>>> Industrial Weather
>>> 763-777-1263
>>> On Wednesday, December 23, 2020 1:32 PM, mdwxman via grass-user <grass-user at lists.osgeo.org> wrote:
>>>> Markus:
>>>> Who knows what the configure means by "TIFF missing?" But here's the configure file and the result:
>>>> (base) [root at godelsrevenge grass-7.8.5]# ./configure \
>>>>> --with-cxx \
>>>>> --with-gdal=/usr/bin/gdal-config \
>>>>> --with-proj --with-proj-share=/usr/share/proj \
>>>>> --with-geos \
>>>>> --with-sqlite \
>>>>> --with-nls \
>>>>> --with-wxwidgets=/usr/bin/wx-config \
>>>>> --with-fftw \
>>>>> --with-cairo --with-cairo-ldflags=-ldfontconfig \
>>>>> --with-freetype --with-freetype-includes=/usr/include/freetype2 \
>>>>> --enable-largefile \
>>>>> --without-odbc \
>>>>> --with-blas --with-blas-includes=/usr/include/atlas-x86_64-base/ \
>>>>> --with-lapack --with-lapack-includes=/usr/include/atlas-x86_64-base/ \
>>>>> --with-zstd
>>>> checking host system type... x86_64-pc-linux-gnu
>>>> checking for gcc... gcc
>>>> checking whether the C compiler (gcc ) works... yes
>>>> checking whether the C compiler (gcc ) is a cross-compiler... no
>>>> checking whether we are using GNU C... yes
>>>> checking whether gcc accepts -g... yes
>>>> checking for Cygwin environment... no
>>>> checking for mingw32 environment... no
>>>> checking for executable suffix... no
>>>> checking for full floating-point support... yes
>>>> checking for pwd... /usr/bin/pwd
>>>> checking for source directory... /grass-7.8.5
>>>> checking for build directory... /grass-7.8.5
>>>> checking for git... /usr/bin/git
>>>> fatal: not a git repository (or any of the parent directories): .git
>>>> checking for MacOSX App... no
>>>> checking for MacOSX architectures... no
>>>> checking for MacOSX SDK... no
>>>> checking how to build libraries... shared
>>>> checking for additional include dirs...
>>>> checking for additional library dirs...
>>>> checking for a BSD compatible install... /usr/bin/install -c
>>>> checking for flex... flex
>>>> checking for yywrap in -lfl... no
>>>> checking for bison... bison -y
>>>> checking for ranlib... ranlib
>>>> checking for ar... ar
>>>> checking for env... env
>>>> checking for perl... /usr/bin/perl
>>>> checking how to run the C preprocessor... gcc -E
>>>> checking for ANSI C header files... yes
>>>> checking for limits.h... yes
>>>> checking for termio.h... yes
>>>> checking for termios.h... yes
>>>> checking for unistd.h... yes
>>>> checking for values.h... yes
>>>> checking for f2c.h... no
>>>> checking for g2c.h... no
>>>> checking for sys/ioctl.h... yes
>>>> checking for sys/mtio.h... yes
>>>> checking for sys/resource.h... yes
>>>> checking for sys/time.h... yes
>>>> checking for sys/timeb.h... yes
>>>> checking for sys/types.h... yes
>>>> checking for sys/utsname.h... yes
>>>> checking for libintl.h... yes
>>>> checking for iconv.h... yes
>>>> checking for langinfo.h... yes
>>>> checking whether time.h and sys/time.h may both be included... yes
>>>> checking for off_t... yes
>>>> checking for uid_t in sys/types.h... yes
>>>> checking return type of signal handlers... void
>>>> checking for ftime... yes
>>>> checking for gethostname... yes
>>>> checking for gettimeofday... yes
>>>> checking for lseek... yes
>>>> checking for nice... yes
>>>> checking for time... yes
>>>> checking for uname... yes
>>>> checking for seteuid... yes
>>>> checking for setpriority... yes
>>>> checking for setreuid... yes
>>>> checking for setruid... no
>>>> checking for drand48... yes
>>>> checking for putenv... yes
>>>> checking for setenv... yes
>>>> checking for nanosleep... yes
>>>> checking whether setpgrp takes no argument... yes
>>>> checking for long long int... yes
>>>> checking for int64_t... yes
>>>> checking for W11... no
>>>> checking for X... libraries , headers
>>>> checking for dnet_ntoa in -ldnet... no
>>>> checking for dnet_ntoa in -ldnet_stub... no
>>>> checking for gethostbyname... yes
>>>> checking for connect... yes
>>>> checking for remove... yes
>>>> checking for shmat... yes
>>>> checking for IceConnectionNumber in -lICE... yes
>>>> checking for library containing cuserid... none required
>>>> checking for asprintf... yes
>>>> checking for atan... no
>>>> checking for atan in -lm... yes
>>>> checking for dlsym... no
>>>> checking for dlsym in -ldl... yes
>>>> checking for iconv... yes
>>>> checking for socket... yes
>>>> checking for location of zlib includes...
>>>> checking for zlib.h... yes
>>>> checking for location of zlib library...
>>>> checking for deflate in -lz... yes
>>>> checking whether to use bzlib... no
>>>> checking whether to use zstd... yes
>>>> checking for location of zstd includes...
>>>> checking for zstd.h... yes
>>>> checking for location of zstd library...
>>>> checking for ZSTD_compress in -lzstd... yes
>>>> checking for location of External PROJ includes...
>>>> checking for proj.h... yes
>>>> checking External PROJ major version... 6
>>>> checking External PROJ minor version... 3
>>>> checking External PROJ patch version... 2
>>>> found PROJ version 6.3.2
>>>> using new PROJ version 5+ API
>>>> checking for location of External PROJ library...
>>>> checking for proj_pj_info in -lproj... yes
>>>> checking for location of External PROJ data files... /usr/share/proj
>>>> checking whether to use regex... yes
>>>> checking for location of regex includes...
>>>> checking for regex.h... yes
>>>> checking for location of regex library...
>>>> checking for regcomp... yes
>>>> checking whether to use Readline... no
>>>> checking whether to use GDAL... yes
>>>> checking for gdal-config... /usr/bin/gdal-config
>>>> checking whether to use libLAS... no
>>>> checking whether to use PDAL... no
>>>> checking whether to use NetCDF... no
>>>> checking whether to use GEOS... yes
>>>> checking for geos-config... /usr/bin/geos-config
>>>> checking for geos_c.h... yes
>>>> checking for initGEOS in -lgeos_c... yes
>>>> checking whether to use TIFF... yes
>>>> checking for location of TIFF includes...
>>>> checking for tiffio.h... no
>>>> configure: error: *** Unable to locate TIFF includes.
>>>> I hope you can see something. I've now memorized the ./configure text!! I see the next-to-last line:
>>>> "checking for tiffio.h" and the response: "no" hmmm. I don't know what that means. Maybe you can explain it.
>>>> Michael Allen
>>>> Industrial Weather
>>>> 763-777-1263
>> grass-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201223/6e9c76fa/attachment-0001.html>
