[GRASS-user] configure file for Fedora 33 and grass-7.8.5
mdwxman
mdwxman at protonmail.com
Wed Dec 23 15:39:38 PST 2020
GRASS GIS 7.8.5 exported compilation log
Started compilation: Wed Dec 23 04:40:02 PM CST 2020
Errors in:
No errors detected.
Finished compilation: Wed Dec 23 04:40:40 PM CST 2020
SUCCESS!! There was another small hiccough (or is that now spelled differently? The cairo library also needed the devel files and a very small error during compilation as ~/raster3d/r3.in.asciialso needed to be compiled. Still, GRASS 7.8.5 is alive.
Thank you Markus for all your patience and help.
Michael Allen
Industrial Weather
763-777-1263
Sent with [ProtonMail](https://protonmail.com) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Wednesday, December 23, 2020 3:14 PM, mdwxman via grass-user <grass-user at lists.osgeo.org> wrote:
> Yeah, I noticed that. Libtiff-devel now installed.
> Michael Allen
> Industrial Weather
> 763-777-1263
> On Wednesday, December 23, 2020 2:08 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> Hi
>> You need to install the development package as well which includes the header .h files:
>> libtiff-devel
>> Markus
>> mdwxman via grass-user <grass-user at lists.osgeo.org> schrieb am Mi., 23. Dez. 2020, 20:39:
>>> And here's what I get from the dnf install libtiff:
>>> (base) [root at godelsrevenge ~]# dnf install libtiff
>>> Fedora Modular 33 - x86_64 - Updates 40 kB/s | 15 kB 00:00
>>> Fedora 33 - x86_64 - Updates 54 kB/s | 16 kB 00:00
>>> Package libtiff-4.1.0-4.fc33.x86_64 is already installed.
>>> Dependencies resolved.
>>> Nothing to do.
>>> Complete!
>>> Could it be that the Fedora 33 gremlins have inserted a differently-named libtiff version or a different location?
>>> Michael Allen
>>> Industrial Weather
>>> 763-777-1263
>>> On Wednesday, December 23, 2020 1:35 PM, mdwxman <mdwxman at protonmail.com> wrote:
>>>> Evidently "TIFF" corresponds to libtiff. I'll attempt to dnf install.
>>>> Michael Allen
>>>> Industrial Weather
>>>> 763-777-1263
>>>> On Wednesday, December 23, 2020 1:32 PM, mdwxman via grass-user <grass-user at lists.osgeo.org> wrote:
>>>>> Markus:
>>>>> Who knows what the configure means by "TIFF missing?" But here's the configure file and the result:
>>>>> (base) [root at godelsrevenge grass-7.8.5]# ./configure \
>>>>>> --with-cxx \
>>>>>> --with-gdal=/usr/bin/gdal-config \
>>>>>> --with-proj --with-proj-share=/usr/share/proj \
>>>>>> --with-geos \
>>>>>> --with-sqlite \
>>>>>> --with-nls \
>>>>>> --with-wxwidgets=/usr/bin/wx-config \
>>>>>> --with-fftw \
>>>>>> --with-cairo --with-cairo-ldflags=-ldfontconfig \
>>>>>> --with-freetype --with-freetype-includes=/usr/include/freetype2 \
>>>>>> --enable-largefile \
>>>>>> --without-odbc \
>>>>>> --with-blas --with-blas-includes=/usr/include/atlas-x86_64-base/ \
>>>>>> --with-lapack --with-lapack-includes=/usr/include/atlas-x86_64-base/ \
>>>>>> --with-zstd
>>>>> checking host system type... x86_64-pc-linux-gnu
>>>>> checking for gcc... gcc
>>>>> checking whether the C compiler (gcc ) works... yes
>>>>> checking whether the C compiler (gcc ) is a cross-compiler... no
>>>>> checking whether we are using GNU C... yes
>>>>> checking whether gcc accepts -g... yes
>>>>> checking for Cygwin environment... no
>>>>> checking for mingw32 environment... no
>>>>> checking for executable suffix... no
>>>>> checking for full floating-point support... yes
>>>>> checking for pwd... /usr/bin/pwd
>>>>> checking for source directory... /grass-7.8.5
>>>>> checking for build directory... /grass-7.8.5
>>>>> checking for git... /usr/bin/git
>>>>> fatal: not a git repository (or any of the parent directories): .git
>>>>> checking for MacOSX App... no
>>>>> checking for MacOSX architectures... no
>>>>> checking for MacOSX SDK... no
>>>>> checking how to build libraries... shared
>>>>> checking for additional include dirs...
>>>>> checking for additional library dirs...
>>>>> checking for a BSD compatible install... /usr/bin/install -c
>>>>> checking for flex... flex
>>>>> checking for yywrap in -lfl... no
>>>>> checking for bison... bison -y
>>>>> checking for ranlib... ranlib
>>>>> checking for ar... ar
>>>>> checking for env... env
>>>>> checking for perl... /usr/bin/perl
>>>>> checking how to run the C preprocessor... gcc -E
>>>>> checking for ANSI C header files... yes
>>>>> checking for limits.h... yes
>>>>> checking for termio.h... yes
>>>>> checking for termios.h... yes
>>>>> checking for unistd.h... yes
>>>>> checking for values.h... yes
>>>>> checking for f2c.h... no
>>>>> checking for g2c.h... no
>>>>> checking for sys/ioctl.h... yes
>>>>> checking for sys/mtio.h... yes
>>>>> checking for sys/resource.h... yes
>>>>> checking for sys/time.h... yes
>>>>> checking for sys/timeb.h... yes
>>>>> checking for sys/types.h... yes
>>>>> checking for sys/utsname.h... yes
>>>>> checking for libintl.h... yes
>>>>> checking for iconv.h... yes
>>>>> checking for langinfo.h... yes
>>>>> checking whether time.h and sys/time.h may both be included... yes
>>>>> checking for off_t... yes
>>>>> checking for uid_t in sys/types.h... yes
>>>>> checking return type of signal handlers... void
>>>>> checking for ftime... yes
>>>>> checking for gethostname... yes
>>>>> checking for gettimeofday... yes
>>>>> checking for lseek... yes
>>>>> checking for nice... yes
>>>>> checking for time... yes
>>>>> checking for uname... yes
>>>>> checking for seteuid... yes
>>>>> checking for setpriority... yes
>>>>> checking for setreuid... yes
>>>>> checking for setruid... no
>>>>> checking for drand48... yes
>>>>> checking for putenv... yes
>>>>> checking for setenv... yes
>>>>> checking for nanosleep... yes
>>>>> checking whether setpgrp takes no argument... yes
>>>>> checking for long long int... yes
>>>>> checking for int64_t... yes
>>>>> checking for W11... no
>>>>> checking for X... libraries , headers
>>>>> checking for dnet_ntoa in -ldnet... no
>>>>> checking for dnet_ntoa in -ldnet_stub... no
>>>>> checking for gethostbyname... yes
>>>>> checking for connect... yes
>>>>> checking for remove... yes
>>>>> checking for shmat... yes
>>>>> checking for IceConnectionNumber in -lICE... yes
>>>>> checking for library containing cuserid... none required
>>>>> checking for asprintf... yes
>>>>> checking for atan... no
>>>>> checking for atan in -lm... yes
>>>>> checking for dlsym... no
>>>>> checking for dlsym in -ldl... yes
>>>>> checking for iconv... yes
>>>>> checking for socket... yes
>>>>> checking for location of zlib includes...
>>>>> checking for zlib.h... yes
>>>>> checking for location of zlib library...
>>>>> checking for deflate in -lz... yes
>>>>> checking whether to use bzlib... no
>>>>> checking whether to use zstd... yes
>>>>> checking for location of zstd includes...
>>>>> checking for zstd.h... yes
>>>>> checking for location of zstd library...
>>>>> checking for ZSTD_compress in -lzstd... yes
>>>>> checking for location of External PROJ includes...
>>>>> checking for proj.h... yes
>>>>> checking External PROJ major version... 6
>>>>> checking External PROJ minor version... 3
>>>>> checking External PROJ patch version... 2
>>>>> found PROJ version 6.3.2
>>>>> using new PROJ version 5+ API
>>>>> checking for location of External PROJ library...
>>>>> checking for proj_pj_info in -lproj... yes
>>>>> checking for location of External PROJ data files... /usr/share/proj
>>>>> checking whether to use regex... yes
>>>>> checking for location of regex includes...
>>>>> checking for regex.h... yes
>>>>> checking for location of regex library...
>>>>> checking for regcomp... yes
>>>>> checking whether to use Readline... no
>>>>> checking whether to use GDAL... yes
>>>>> checking for gdal-config... /usr/bin/gdal-config
>>>>> checking whether to use libLAS... no
>>>>> checking whether to use PDAL... no
>>>>> checking whether to use NetCDF... no
>>>>> checking whether to use GEOS... yes
>>>>> checking for geos-config... /usr/bin/geos-config
>>>>> checking for geos_c.h... yes
>>>>> checking for initGEOS in -lgeos_c... yes
>>>>> checking whether to use TIFF... yes
>>>>> checking for location of TIFF includes...
>>>>> checking for tiffio.h... no
>>>>> configure: error: *** Unable to locate TIFF includes.
>>>>> I hope you can see something. I've now memorized the ./configure text!! I see the next-to-last line:
>>>>> "checking for tiffio.h" and the response: "no" hmmm. I don't know what that means. Maybe you can explain it.
>>>>> Michael Allen
>>>>> Industrial Weather
>>>>> 763-777-1263
>>> grass-user mailing list
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201223/535f2413/attachment-0001.html>
