[GRASS-user] Scatter plot cannot be added
Micha Silver
tsvibar at gmail.com
Sat Dec 26 05:39:18 PST 2020
On 12/25/20 11:46 PM, mega saputra wrote:
> Sorry, there is holiday.
> I import the raster. Then set the region. This is my syntax :
> g.region -up raster=rgb.1
The "-u" flag does not set the current computational region to your
raster. It just reports what would happen if you do reset the region.
Please try:
g.region -ap rast=rgb.1
and report back the output.
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 13:07:42.9N
> south: 27:38:15.5S
> west: 100:55:15.7E
> east: 131:15:38.1E
> nsres: 0:00:36.8
> ewres: 0:00:36.8
> rows: 3988
> cols: 2968
> cells: 11836384
> (Sat Dec 26 05:24:05 2020) Command finished (0 sec)
> Then, from menu Imagery > Classify image > Interactive input for
> supervised classification. Then the output is like this :
> G__open(read): Unable to open '/home/mega/newLocation/PERMAN
> ENT/.tmp/mega/vector/trAreas114130/frmt': No such file or
> directory
> I don't know why there is that message.
> Then in Plots Menu, I choose Scatter Plots. I click Add scatter plot.
> In the Name of imagery group, I choose the raster. In the Name of
> imagery subgroup, I type the name. I click Create/edit group. In x and
> y axis, I choose a band. I click Add. Then there is a message that :
> "Scatter plot cannot be added.
> Multiple of bands ranges <x53.1 at PERMANENT:65529 *
> x53.1 at PERMANENT:65529 = 4294049841 > is higher than maximum limit
> <16810000> "
> In this case, I have defined the region. Thank you for your attention.
> Regards,
> mega
> On Wed, Dec 23, 2020 at 4:30 PM Micha Silver <tsvibar at gmail.com
> <mailto:tsvibar at gmail.com>> wrote:
> On 12/23/20 5:09 AM, mega saputra wrote:
> > Hello guys,
> > I have MODIS data. It is sixteen bit unsigned integer. When I
> want to
> > add scatter plot, there is a warning :
> > <16810000> "
> Please post your computation region (i.e. the output of g.region
> -p) and
> the command you used.
> > So, how to make big maximum limit on Grass GIS, so that I can add
> > scatter plot of MODIS data?
> > Regards,
> > mega
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-user
> <https://lists.osgeo.org/mailman/listinfo/grass-user>
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
Micha Silver
Ben Gurion Univ.
