[GRASS-user] Scatter plot cannot be added
mega saputra megasaputra8 at gmail.com
Sat Dec 26 13:40:57 PST 2020
The result is the same. It cannot add scatterplot.
Here is the output :
(Sun Dec 27 05:20:25 2020)
g.region -ap raster=rgb.1
projection: 3 (Latitude-Longitude)
zone:       0
datum:      wgs84
ellipsoid:  wgs84
north:      13:07:42.9N
south:      27:38:15.5S
west:       100:55:15.7E
east:       131:15:38.1E
nsres:      0:00:36.8
ewres:      0:00:36.8
rows:       3988
cols:       2968
cells:      11836384
(Sun Dec 27 05:20:25 2020) Command finished (0 sec)
G__open(read): Unable to open '/home/mega/newLocation/PERMAN
ENT/.tmp/mega/vector/trAreas54950/frmt': No such file or
directory
If you want to try my data, my data is in :
https://1drv.ms/u/s!AjXAWS5maHffhyH0q9oTos1umy3D?e=bKa7mX
Thank you.
regards,
mega
On Sat, Dec 26, 2020 at 9:39 PM Micha Silver <tsvibar at gmail.com> wrote:
> On 12/25/20 11:46 PM, mega saputra wrote:
> > Sorry, there is holiday.
> > I import the raster. Then set the region. This is my syntax :
> > g.region -up raster=rgb.1
> The "-u" flag does not set the current computational region to your
> raster. It just reports what would happen if you do reset the region.
> Please try:
> g.region -ap rast=rgb.1
> and report back the output.
> > zone:       0
> > datum:      wgs84
> > ellipsoid:  wgs84
> > north:      13:07:42.9N
> > south:      27:38:15.5S
> > west:       100:55:15.7E
> > east:       131:15:38.1E
> > nsres:      0:00:36.8
> > ewres:      0:00:36.8
> > rows:       3988
> > cols:       2968
> > cells:      11836384
> > (Sat Dec 26 05:24:05 2020) Command finished (0 sec)
> > Then, from menu Imagery > Classify image > Interactive input for
> > supervised classification. Then the output is like this :
> > ENT/.tmp/mega/vector/trAreas114130/frmt': No such file or
> > directory
> > I don't know why there is that message.
> > Then in Plots Menu, I choose Scatter Plots. I click Add scatter plot.
> > In the Name of imagery group, I choose the raster. In the Name of
> > imagery subgroup, I type the name. I click Create/edit group. In x and
> > y axis, I choose a band. I click Add. Then there is a message that :
> > "Scatter plot cannot be added.
> > Multiple of bands ranges <x53.1 at PERMANENT:65529 *
> > x53.1 at PERMANENT:65529 = 4294049841 > is higher than maximum limit
> > <16810000> "
> > In this case, I have defined the region. Thank you for your attention.
> > Regards,
> > mega
> > On Wed, Dec 23, 2020 at 4:30 PM Micha Silver <tsvibar at gmail.com
> > <mailto:tsvibar at gmail.com>> wrote:
> >     On 12/23/20 5:09 AM, mega saputra wrote:
> >     > Hello guys,
> >     > I have MODIS data. It is sixteen bit unsigned integer. When I
> >     want to
> >     > add scatter plot, there is a warning :
> >     > <16810000> "
> >     Please post your computation region (i.e. the output of g.region
> >     -p) and
> >     the command you used.
> >     > So, how to make big maximum limit on Grass GIS, so that I can add
> >     > scatter plot of MODIS data?
> >     > Regards,
> >     > mega
> >     > _______________________________________________
> >     > grass-user mailing list
> >     > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> >     > https://lists.osgeo.org/mailman/listinfo/grass-user
> >     <https://lists.osgeo.org/mailman/listinfo/grass-user>
> >     Micha Silver
> >     Ben Gurion Univ.
> >     Sde Boker, Remote Sensing Lab
> >     cell: +972-523-665918
> Micha Silver
> Ben Gurion Univ.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201227/420aca2e/attachment.html>
