[GRASS-user] Scatter plot cannot be added
mega saputra megasaputra8 at gmail.com
Mon Dec 28 15:31:58 PST 2020
I guess Grass GIS can create interactive scatter plot from my data.
Because, in other menu on Grass GIS (not in interactive scatter plot), it
can create a scatter plot.
I will post new email in new title as your suggestion about interactive
scatter plot.
Thank you for your response.
Regards,
mega
On Mon, Dec 28, 2020 at 3:28 PM Micha Silver <tsvibar at gmail.com> wrote:
> On 12/28/2020 1:38 AM, mega saputra wrote:
> Here is the output :
> g.proj -p
> But, there is no scatter plot in Map Display. Then I click twice in vector
> > scatter_1_3 in Data tab. Then there is a message :
> "Unable to zoom to vector map <scatter_1_3 at PERMANENT>
> Details: Illegal latitude for North: 65528"
> Yes, that's correct. You need to understand how r.scatterplot works. The
> X-Y coordinates in the newly created point vector layer are the raster
> values at each pixel of the original rasters. In this case, since the
> original are color bands, the values represent reflectance for each band.
> These values can go as high as 65528, which is way beyond the range in a
> latitude/longitude coordinate system (maximum long/lat of 360 X 180).
> If you want to carry on with this (in your next mail you are beginning
> with the interactive scatter plot), it might be helpful to export the X-Y
> "coordinates" to a text file for plotting in some other software. Just keep
> in mind that you will get a list of 12,000,000 rows with two columns of
> numbers-the reflectances of both bands.
> How to solve the problem?
> Regards,
> mega
> On Sun, Dec 27, 2020 at 3:22 PM Micha Silver <tsvibar at gmail.com> wrote:
>> Here's my attempt:
>> I downloaded the rgb.tif that you linked to, then used it to create a
>> new, fresh location
>> # Create a NEW location "mega" using the georeferenced rgb.tif file to
>> define location
>> # and import the file
>> # Run at the command line, *before* starting grass:
>> grass78 -c rgb.tif /home/micha/grass/mega
>> # Now at the grass prompt:
>> # Check projection settings
>> g.proj -p
>> -PROJ_INFO-------------------------------------------------
>> datum      : wgs84
>> ellps      : wgs84
>> proj       : ll
>> no_defs    : defined
>> -PROJ_EPSG-------------------------------------------------
>> epsg       : 4326
>> -PROJ_UNITS------------------------------------------------
>> unit       : degree
>> units      : degrees
>> meters     : 1.0
>> # Install the scatterplot extension
>> g.extension r.scatterplot
>> Downloading precompiled GRASS Addons <r.scatterplot>...
>> Updating extensions metadata file...
>> Updating extension modules metadata file...
>> Installation of <r.scatterplot> successfully finished
>> # Now run r.scatterplot on two bands
>> r.scatterplot input=rgb.3,rgb.2 output=scatter_3_2
>>  100%
>> Building topology for vector map <scatter_3_2 at PERMANENT>...
>> Registering primitives...
>>   11830000
>> # Almost 12 million points (!)
>> The X-Y coordinates of the points are the scatterplot values.
>> HTH,
>> Micha
>> On 12/26/2020 11:40 PM, mega saputra wrote:
>> The result is the same. It cannot add scatterplot.
>> (Sun Dec 27 05:20:25 2020)
>> g.region -ap raster=rgb.1
>> projection: 3 (Latitude-Longitude)
>> zone:       0
>> datum:      wgs84
>> ellipsoid:  wgs84
>> north:      13:07:42.9N
>> south:      27:38:15.5S
>> west:       100:55:15.7E
>> east:       131:15:38.1E
>> nsres:      0:00:36.8
>> ewres:      0:00:36.8
>> rows:       3988
>> cols:       2968
>> cells:      11836384
>> (Sun Dec 27 05:20:25 2020) Command finished (0 sec)
>> G__open(read): Unable to open '/home/mega/newLocation/PERMAN
>> ENT/.tmp/mega/vector/trAreas54950/frmt': No such file or
>> directory
>> If you want to try my data, my data is in :
>> https://1drv.ms/u/s!AjXAWS5maHffhyH0q9oTos1umy3D?e=bKa7mX
>> Thank you.
>> regards,
>> mega
>> On Sat, Dec 26, 2020 at 9:39 PM Micha Silver <tsvibar at gmail.com> wrote:
>>> On 12/25/20 11:46 PM, mega saputra wrote:
>>> > Sorry, there is holiday.
>>> > I import the raster. Then set the region. This is my syntax :
>>> > g.region -up raster=rgb.1
>>> The "-u" flag does not set the current computational region to your
>>> raster. It just reports what would happen if you do reset the region.
>>> Please try:
>>> g.region -ap rast=rgb.1
>>> and report back the output.
>>> > zone:       0
>>> > datum:      wgs84
>>> > ellipsoid:  wgs84
>>> > north:      13:07:42.9N
>>> > south:      27:38:15.5S
>>> > west:       100:55:15.7E
>>> > east:       131:15:38.1E
>>> > nsres:      0:00:36.8
>>> > ewres:      0:00:36.8
>>> > rows:       3988
>>> > cols:       2968
>>> > cells:      11836384
>>> > (Sat Dec 26 05:24:05 2020) Command finished (0 sec)
>>> > Then, from menu Imagery > Classify image > Interactive input for
>>> > supervised classification. Then the output is like this :
>>> > ENT/.tmp/mega/vector/trAreas114130/frmt': No such file or
>>> > directory
>>> > I don't know why there is that message.
>>> > Then in Plots Menu, I choose Scatter Plots. I click Add scatter plot.
>>> > In the Name of imagery group, I choose the raster. In the Name of
>>> > imagery subgroup, I type the name. I click Create/edit group. In x and
>>> > y axis, I choose a band. I click Add. Then there is a message that :
>>> > "Scatter plot cannot be added.
>>> > Multiple of bands ranges <x53.1 at PERMANENT:65529 *
>>> > x53.1 at PERMANENT:65529 = 4294049841 > is higher than maximum limit
>>> > <16810000> "
>>> > In this case, I have defined the region. Thank you for your attention.
>>> > Regards,
>>> > mega
>>> > On Wed, Dec 23, 2020 at 4:30 PM Micha Silver <tsvibar at gmail.com
>>> > <mailto:tsvibar at gmail.com>> wrote:
>>> >     On 12/23/20 5:09 AM, mega saputra wrote:
>>> >     > Hello guys,
>>> >     > I have MODIS data. It is sixteen bit unsigned integer. When I
>>> >     want to
>>> >     > add scatter plot, there is a warning :
>>> limit
>>> >     > <16810000> "
>>> >     Please post your computation region (i.e. the output of g.region
>>> >     -p) and
>>> >     the command you used.
>>> >     > So, how to make big maximum limit on Grass GIS, so that I can add
>>> >     > scatter plot of MODIS data?
>>> >     > Regards,
>>> >     > mega
>>> >     > _______________________________________________
>>> >     > grass-user mailing list
>>> >     > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>> >     > https://lists.osgeo.org/mailman/listinfo/grass-user
>>> >     <https://lists.osgeo.org/mailman/listinfo/grass-user>
>>> >     Micha Silver
>>> >     Ben Gurion Univ.
>>> >     Sde Boker, Remote Sensing Lab
>>> >     cell: +972-523-665918
>>> Micha Silver
>>> Ben Gurion Univ.
>> Micha Silver
>> Remote Sensing Lab, Sde Boker
>> Ben Gurion University
> Micha Silver
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201229/f045fb40/attachment.html>
