[GRASS-user] Scatter plot cannot be added in interactive scatter plot
mega saputra megasaputra8 at gmail.com
Wed Dec 30 21:34:26 PST 2020
The answer for your question :
1. I really input band1 for x axis and band3 for y axis. I don't know the
message tell rgb1*rgb1. May be it just gives information about dimension.
You can see in screenshot-1.
2. Actually I don't want to downscale. Because the digital number will
vague.
Btw I have tried and I rescale the data with recommendation of GRASS GIS.
Recommendation limit is 4000000. So, I rescale to 2000.
(Thu Dec 31 13:02:58 2020)
r.rescale input=rgb.5 output=rgb.5.rescale to=0,1999 --o
Rescale rgb.5[0,65528] to rgb.5.rescale[0,1999]
(Thu Dec 31 13:02:59 2020) Command finished (0 sec)
(Thu Dec 31 13:03:09 2020)
r.rescale input=rgb.4 output=rgb.4.rescale to=0,1999 --o
Rescale rgb.4[0,65528] to rgb.4.rescale[0,1999]
(Thu Dec 31 13:03:10 2020) Command finished (0 sec)
(Thu Dec 31 13:03:20 2020)
r.rescale input=rgb.3 output=rgb.3.rescale to=0,1999 --o
Rescale rgb.3[0,65528] to rgb.3.rescale[0,1999]
(Thu Dec 31 13:03:21 2020) Command finished (0 sec)
(Thu Dec 31 13:03:41 2020)
r.rescale input=rgb.2 output=rgb.2.rescale to=0,1999 --o
Rescale rgb.2[0,65528] to rgb.2.rescale[0,1999]
(Thu Dec 31 13:03:42 2020) Command finished (0 sec)
(Thu Dec 31 13:03:54 2020)
r.rescale input=rgb.1 output=rgb.1.rescale to=0,1999 --o
Rescale rgb.1[0,65528] to rgb.1.rescale[0,1999]
(Thu Dec 31 13:03:55 2020) Command finished (0 sec
Then I group the result with command i.group.
Then, from menu Imagery > Classify image > Interactive input for supervised
classification. Then I succeed to create interactive scatter plot
(screenshot-2).
In this window I can create polygon in scatter plot, but no effect with the
raster like in https://grass.osgeo.org/grass78/manuals/wxGUI.iscatt.html.
May be I will ask in new topic in new email.
Thank you.
On Tue, Dec 29, 2020 at 6:49 PM Micha Silver <tsvibar at gmail.com> wrote:
> Hello Mega
> On 12/29/20 1:51 AM, mega saputra wrote:
> > Hello guys,
> > I have tried to add (passive) scatter plot with my data, and it is
> > succeed.
> > But, I want to add in interactive scatter plot, and not succeed. The
> > message :
> > "Scatter plot cannot be added. Multiple of bands ranges
> > <rgb.1 at PERMANENT:65529 * rgb.1 at PERMANENT:65529 = 4294049841 > is
> > higher than maximum limit <16810000> "
> Before the interactive scatterplot, can you clarify two questions?
> Why are you trying to plot a band against itself (rgb.1, rgb.1 above) ?
> This will give you 12,000,000 rows where each row contains two identical
> values. So the scatterplot will be essentially a line along 45º.
> Second, with rasters of about 3000x4000 you will get a huge number of
> points in the scatterplot. Would you consider to downscale to a lower
> resolution to make the resulting scatterplot more manageable?
> Now some suggestions:
> The range of reflectance values in your RGB image are up from 0 to
> 65528. But the possible X-Y values in the Long/lat location need to be
> between 0-90 maximum in order to display the scatterplot. So here's a
> way to rescale the reflectance values to display the scatterplot on the
> Map Display.
> # 1- Create new location based on the CRS of the input GeoTiff
> # and import to grass
> grass -c rgb.tif /home/micha/GIS/grass/mega
> r.import input=rgb.tif output=rgb --overwrite
> # imports 5 bands
> # Check univariate statistics of one of the bands
> r.univar rgb.1
>   100%
> total null and non-null cells: 11836384
> total null cells: 0
> Of the non-null cells:
> n: 11836384
> minimum: 0
> maximum: 65528
> range: 65528
> mean: 3982.64
> mean of absolute values: 3982.64
> standard deviation: 4159.48
> variance: 1.73012e+07
> variation coefficient: 104.44 %
> sum: 47140019279
> # Notice that the maximum value can be as high as 65528
> #  (maximum of unsigned short integer)
> # 2- In order to display the scatterplot in a Lon/Lat coordinate system
> # the max value cannot be higher than 90 (maximum latitude)
> # So create rescaled rasters that "squeeze" reflectance values to the
> range 0,90
> r.rescale input=rgb.1 output=rgb.1.rescale to=0,90 --o
> r.rescale input=rgb.2 output=rgb.2.rescale to=0,90 --o
> r.rescale input=rgb.3 output=rgb.3.rescale to=0,90 --o
> r.rescale input=rgb.4 output=rgb.4.rescale to=0,90 --o
> r.rescale input=rgb.5 output=rgb.5.rescale to=0,90 --o
> # 3- Now prepare the scatterplot vector using the rescaled rasters, and
> display
> # 12 million points takes a while...
> # Here I choose the red and NIR bands for the scatterplot
> r.scatterplot input=rgb.3.rescale,rgb.4.rescale out=scatter_3_4 --o
> # See the attached image
> HTH
> > So, how to add in interactive scatter plot?
> > My data in : https://1drv.ms/u/s!AjXAWS5maHffhyH0q9oTos1umy3D?e=bKa7mX
> > <https://1drv.ms/u/s!AjXAWS5maHffhyH0q9oTos1umy3D?e=bKa7mX>
> > regards,
> > mega
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201231/ac6307d4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201231/ac6307d4/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201231/ac6307d4/attachment-0003.png>
