[GRASS-user] Fwd: GRASS GIS problem from OSGeo4W Setup
Valter Albino valteralbino at gmail.com
Sat Feb 1 12:06:44 PST 2020
Regarding the issue, this message is also important (during instalation):
[image: ScreenHunter_31 Feb. 01 20.04.gif]
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
---------- Forwarded message ---------
De: Valter Albino <valteralbino  gmail.com>
Date: sábado, 1/02/2020 à(s) 19:52
Subject: GRASS GIS problem from OSGeo4W Setup
To: grass-user <grass-user  lists.osgeo.org>
Hi
*1)* Trying to install GRASS 7.8.2 or 7.9.dev but have the following
message:
OSGeo4W Setup - Running postinstall scripts
Postinstall script errors
These do not necessarly mean that affectes packages will fail to function
properly, but please check /var/log/setup.log.full and report any problems.
Package: Unknown package
    qgis-common.bat exit code -1073741511
*2)* So, when starting from windows menu, have the follwing message:
Starting GRASS GIS...
Error: Reading settings from file
<C:\Users\Particular\AppData\Roaming\GRASS7\wx> failed.
                Details: not enough values to unpack (expected 2, got 1)
                Line: ''
Using 64bits Windows OS, and having this issue from the 1st time, after
update QGIS and GRASS from OSGeo4W Setup.
Thanks
Cumprimentos,
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200201/29c2ea51/attachment.html>
Name: ScreenHunter_31 Feb. 01 20.04.gif
Type: image/gif
Desc: não disponível
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200201/29c2ea51/attachment.gif>
