[GRASS-user] GRASS GIS problem from OSGeo4W Setup
Valter Albino valteralbino at gmail.com
Sat Feb 1 11:52:24 PST 2020
Hi
*1)* Trying to install GRASS 7.8.2 or 7.9.dev but have the following
message:
OSGeo4W Setup - Running postinstall scripts
Postinstall script errors
These do not necessarly mean that affectes packages will fail to function
properly, but please check /var/log/setup.log.full and report any problems.
Package: Unknown package
    qgis-common.bat exit code -1073741511
*2)* So, when starting from windows menu, have the follwing message:
Starting GRASS GIS...
Error: Reading settings from file
<C:\Users\Particular\AppData\Roaming\GRASS7\wx> failed.
                Details: not enough values to unpack (expected 2, got 1)
                Line: ''
Using 64bits Windows OS, and having this issue from the 1st time, after
update QGIS and GRASS from OSGeo4W Setup.
Thanks
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200201/c1865a68/attachment-0001.html>
