[GRASS-user] Failure to compile GRASS GIS 7.8 with Proj 6 and GDAL 3
Nikos Alexandris
nik at nikosalexandris.net
Tue Feb 4 08:15:17 PST 2020
* Nikos Alexandris <nik at nikosalexandris.net> [2020-02-04 16:51:33 +0100]:
>>regarding PROJ, cleaning up ${prefix}/share with the proj.db and grids is
>>quite important because PROJ is evolving fast and any leftovers from a
>>previous installation might confuse software compiled against PROJ.
>That I forgot to remove :D.
>Won't existing files be overwritten by `make install` as root?
Actually, I did remote the `share/proj` directory too before
re-installing PROJ.
Nikos
