[GRASS-user] Fwd: GRASS GIS problem from OSGeo4W Setup
Valter Albino
valteralbino at gmail.com
Sun Feb 2 03:58:26 PST 2020
Helmut,
Installed QGIS+GRASS but still don't open GRASS GIS. The GRASS module
inside QGIS is OK.
Following the selection of the grassdata directory, gives the message:
Starting GRASS GIS...
WARNING: Concurrent mapset locking is not supported on Windows
Cleaning up temporary files...
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS GIS 7.8.2
GRASS GIS homepage: https://grass.osgeo.org
This version running through: Command Prompt
(C:\WINDOWS\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
Microsoft Windows [Version 10.0.18362.592]
(c) 2019 Microsoft Corporation. Todos os direitos reservados.
C:\>Traceback (most recent call last):
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\wxgui.py", line 107, in
OnInit
workspace=self.workspaceFile)
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\frame.py", line
143, in __init__
self.notebook = self._createNoteBook()
338, in _createNoteBook
gcstyle=GC_PROMPT)
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\gui_core\goutput.py",
line 118, in __init__
self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\gui_core\prompt.py",
line 138, in __init__
GPrompt.__init__(self, parent=parent, menuModel=menuModel)
line 56, in __init__
self.mapList = self._getListOfMaps()
line 100, in _getListOfMaps
result['raster'] = grass.list_strings('raster')
File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\script\core.py",
line 1288, in list_strings
mapset=mapset).splitlines():
line 503, in read_command
return handle_errors(returncode, stdout, args, kwargs)
line 343, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None g.list --q -m
type=raster ended with error
Process ended with non-zero return code 3221225785. See errors in the
(error) output.
OnInit returned false, exiting...
Error in atexit._run_exitfuncs:
wx._core.wxAssertionError: C++ assertion "GetEventHandler() == this" failed
at ..\..\src\common\wincmn.cpp(478) in wxWindowBase::~wxWindowBase(): any
pushed event handlers must have been removed
What should be happening?
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Valter Albino <valteralbino gmail.com> escreveu no dia domingo, 2/02/2020
à(s) 10:58:
> OK, thanks,
> It opens but i'm not able to enter.
> I will erase all and start to install all over again
> Cumprimentos,
> Helmut Kudrnovsky <hellik web.de> escreveu no dia domingo, 2/02/2020 à(s)
> 10:16:
>> Valter Albino wrote
>> > Hi Helmut,
>> > Thanks for reply.
>> > Feel embarrassed, since i can't find the file path you mention.
>> > Tried to install again, but the error remains, starting in the
>> > installation:
>> > [image: Capturar.GIF]
>> > In my portable PC i did the same but didn't give error, so can run GRASS
>> > GIS with no problems.
>> > I didn't change the language
>> > Cumprimentos,
>> > Helmut Kudrnovsky <
>> > hellik@
>> > 08:48:
>> >> Valter Albino wrote
>> >> > Regarding the issue, this message is also important (during
>> >> instalation):
>> >> > [image: ScreenHunter_31 Feb. 01 20.04.gif]
>> >> > Cumprimentos,
>> >> > ---------- Forwarded message ---------
>> >> > De: Valter Albino <
>> >> > valteralbino@
>> >> > Date: sábado, 1/02/2020 à(s) 19:52
>> >> > Subject: GRASS GIS problem from OSGeo4W Setup
>> >> > To: grass-user <
>> >> > grass-user .osgeo
>> >> > Hi
>> >> > *1)* Trying to install GRASS 7.8.2 or 7.9.dev but have the following
>> >> > message:
>> >> > OSGeo4W Setup - Running postinstall scripts
>> >> > Postinstall script errors
>> >> > These do not necessarly mean that affectes packages will fail to
>> >> function
>> >> > properly, but please check /var/log/setup.log.full and report any
>> >> > problems.
>> >> > Package: Unknown package
>> >> > qgis-common.bat exit code -1073741511
>> >> > *2)* So, when starting from windows menu, have the follwing message:
>> >> > Error: Reading settings from file
>> >> > <C:\Users\Particular\AppData\Roaming\GRASS7\wx> failed.
>> >> > Details: not enough values to unpack (expected 2, got
>> >> 1)
>> >> > Line: ''
>> >> > Using 64bits Windows OS, and having this issue from the 1st time,
>> after
>> >> > update QGIS and GRASS from OSGeo4W Setup.
>> >> > Thanks
>> >> > Cumprimentos,
>> >> > _______________________________________________
>> >> > grass-user mailing list
>> >> > grass-user .osgeo
>> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
>> >> > ScreenHunter_31 Feb. 01 20.04.gif (15K)
>> http://osgeo-org.1560.x6.nabble.com/attachment/5428909/0/ScreenHunter_31%20Feb.%2001%2020.04.gif>
>> >> It's part of the OSGeo4W repackaging. Try to reinstall.
>> >> best regards
>> >> Helmut
>> >> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>> > grass-user .osgeo
>> > grass-user .osgeo
>> > Capturar.GIF (140K)
>> http://osgeo-org.1560.x6.nabble.com/attachment/5428927/0/Capturar.GIF>
>> The path is something like
>> C:\users\yourusername\appdata\...\roaming\grass7
>> Do a search for grass7 in the appdata subfolder.
>> Or copy
>> %APPDATA%
>> in the Windows file explorer to open directly the appdata folder.
>> best regards
>> Helmut
>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>> grass-user lists.osgeo.org
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200202/3ffc1891/attachment-0001.html>
