[GRASS-user] Fwd: GRASS GIS problem from OSGeo4W Setup
Helmut Kudrnovsky
hellik at web.de
Sun Feb 2 04:07:57 PST 2020
Valter Albino wrote
> OK, thanks,
> It opens but i'm not able to enter.
> I will erase all and start to install all over again
> Cumprimentos,
> *Valter Albino -* Geógrafo Físico, M.Sc.
> Modelação H&H / Riscos ambientais / OT&U
> www.valteralbino.wixsite.com/hydrodynamics
> Helmut Kudrnovsky <
> hellik@
> > escreveu no dia domingo, 2/02/2020 à(s)
> 10:16:
>> Valter Albino wrote
>> > Hi Helmut,
>> > Thanks for reply.
>> > Feel embarrassed, since i can't find the file path you mention.
>> > Tried to install again, but the error remains, starting in the
>> > installation:
>> > [image: Capturar.GIF]
>> > In my portable PC i did the same but didn't give error, so can run
>> GRASS
>> > GIS with no problems.
>> > I didn't change the language
>> > Cumprimentos,
>> > Helmut Kudrnovsky <
>> > hellik@
>> > 08:48:
>> >> Valter Albino wrote
>> >> > Regarding the issue, this message is also important (during
>> >> instalation):
>> >> > [image: ScreenHunter_31 Feb. 01 20.04.gif]
>> >> > Cumprimentos,
>> >> > ---------- Forwarded message ---------
>> >> > De: Valter Albino <
>> >> > valteralbino@
>> >> > Date: sábado, 1/02/2020 à(s) 19:52
>> >> > Subject: GRASS GIS problem from OSGeo4W Setup
>> >> > To: grass-user <
>> >> > grass-user at .osgeo
>> >> > Hi
>> >> > *1)* Trying to install GRASS 7.8.2 or 7.9.dev but have the following
>> >> > message:
>> >> > OSGeo4W Setup - Running postinstall scripts
>> >> > Postinstall script errors
>> >> > These do not necessarly mean that affectes packages will fail to
>> >> function
>> >> > properly, but please check /var/log/setup.log.full and report any
>> >> > problems.
>> >> > Package: Unknown package
>> >> > qgis-common.bat exit code -1073741511
>> >> > *2)* So, when starting from windows menu, have the follwing message:
>> >> > Starting GRASS GIS...
>> >> > Error: Reading settings from file
>> >> > <C:\Users\Particular\AppData\Roaming\GRASS7\wx> failed.
>> >> > Details: not enough values to unpack (expected 2,
>> got
>> >> 1)
>> >> > Line: ''
>> >> > Using 64bits Windows OS, and having this issue from the 1st time,
>> after
>> >> > update QGIS and GRASS from OSGeo4W Setup.
>> >> > Thanks
>> >> > Cumprimentos,
>> >> > _______________________________________________
>> >> > grass-user mailing list
>> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
>> >> > ScreenHunter_31 Feb. 01 20.04.gif (15K)
>> http://osgeo-org.1560.x6.nabble.com/attachment/5428909/0/ScreenHunter_31%20Feb.%2001%2020.04.gif>
>> >> It's part of the OSGeo4W repackaging. Try to reinstall.
>> >> best regards
>> >> Helmut
>> >> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>> > Capturar.GIF (140K)
>> http://osgeo-org.1560.x6.nabble.com/attachment/5428927/0/Capturar.GIF>
>> The path is something like
>> C:\users\yourusername\appdata\...\roaming\grass7
>> Do a search for grass7 in the appdata subfolder.
>> Or copy
>> %APPDATA%
>> in the Windows file explorer to open directly the appdata folder.
>> best regards
>> Helmut
>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
Looks like a dependencies mismatch:
https://grasswiki.osgeo.org/wiki/WinGRASS_errors
Can't reproduce it here in my 64bit OSGeo4W environment
Try to setup a clean OSGeo4W environment
best regards
Helmut
