[GRASS-user] Fwd: GRASS GIS problem from OSGeo4W Setup
Valter Albino
valteralbino at gmail.com
Sun Feb 2 04:24:39 PST 2020
Thanks for the efforts
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Helmut Kudrnovsky <hellik web.de> escreveu no dia domingo, 2/02/2020 à(s)
12:08:
> Valter Albino wrote
> > OK, thanks,
> > It opens but i'm not able to enter.
> > I will erase all and start to install all over again
> > Cumprimentos,
> > Helmut Kudrnovsky <
> > hellik@
> > 10:16:
> >> Valter Albino wrote
> >> > Hi Helmut,
> >> > Thanks for reply.
> >> > Feel embarrassed, since i can't find the file path you mention.
> >> > Tried to install again, but the error remains, starting in the
> >> > installation:
> >> > [image: Capturar.GIF]
> >> > In my portable PC i did the same but didn't give error, so can run
> >> GRASS
> >> > GIS with no problems.
> >> > I didn't change the language
> >> > Cumprimentos,
> >> > Helmut Kudrnovsky <
> >> > hellik@
> >> > 08:48:
> >> >> Valter Albino wrote
> >> >> > Regarding the issue, this message is also important (during
> >> >> instalation):
> >> >> > [image: ScreenHunter_31 Feb. 01 20.04.gif]
> >> >> > Cumprimentos,
> >> >> > ---------- Forwarded message ---------
> >> >> > De: Valter Albino <
> >> >> > valteralbino@
> >> >> > Date: sábado, 1/02/2020 à(s) 19:52
> >> >> > Subject: GRASS GIS problem from OSGeo4W Setup
> >> >> > To: grass-user <
> >> >> > grass-user .osgeo
> >> >> > Hi
> >> >> > *1)* Trying to install GRASS 7.8.2 or 7.9.dev but have the
> following
> >> >> > message:
> >> >> > OSGeo4W Setup - Running postinstall scripts
> >> >> > Postinstall script errors
> >> >> > These do not necessarly mean that affectes packages will fail to
> >> >> function
> >> >> > properly, but please check /var/log/setup.log.full and report any
> >> >> > problems.
> >> >> > Package: Unknown package
> >> >> > qgis-common.bat exit code -1073741511
> >> >> > *2)* So, when starting from windows menu, have the follwing
> message:
> >> >> > Starting GRASS GIS...
> >> >> > Error: Reading settings from file
> >> >> > <C:\Users\Particular\AppData\Roaming\GRASS7\wx> failed.
> >> >> > Details: not enough values to unpack (expected 2,
> >> got
> >> >> 1)
> >> >> > Line: ''
> >> >> > Using 64bits Windows OS, and having this issue from the 1st time,
> >> after
> >> >> > update QGIS and GRASS from OSGeo4W Setup.
> >> >> > Thanks
> >> >> > Cumprimentos,
> >> >> > _______________________________________________
> >> >> > grass-user mailing list
> >> >> > grass-user .osgeo
> >> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
> >> >> > ScreenHunter_31 Feb. 01 20.04.gif (15K)
> http://osgeo-org.1560.x6.nabble.com/attachment/5428909/0/ScreenHunter_31%20Feb.%2001%2020.04.gif>
> >> >> It's part of the OSGeo4W repackaging. Try to reinstall.
> >> >> best regards
> >> >> Helmut
> >> >> Sent from:
> >> http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> >> > grass-user .osgeo
> >> > grass-user .osgeo
> >> > Capturar.GIF (140K)
> http://osgeo-org.1560.x6.nabble.com/attachment/5428927/0/Capturar.GIF>
> >> The path is something like
> >> C:\users\yourusername\appdata\...\roaming\grass7
> >> Do a search for grass7 in the appdata subfolder.
> >> Or copy
> >> %APPDATA%
> >> in the Windows file explorer to open directly the appdata folder.
> >> best regards
> >> Helmut
> >> Sent from:
> > grass-user .osgeo
> > grass-user .osgeo
> Looks like a dependencies mismatch:
> https://grasswiki.osgeo.org/wiki/WinGRASS_errors
> Can't reproduce it here in my 64bit OSGeo4W environment
> Try to setup a clean OSGeo4W environment
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user lists.osgeo.org
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200202/6af2bde1/attachment.html>
