[GRASS-user] Fwd: GRASS GIS problem from OSGeo4W Setup
Valter Albino valteralbino at gmail.com
Sun Feb 2 05:40:01 PST 2020
Helmut
Find the issue posted by Pedro Venâncio [
http://osgeo-org.1560.x6.nabble.com/Re-GRASS-user-WinGRASS-build-up-WIP-td5421814.html
Also have the gdal300.dll:
[image: imagem.png]
Maybe the same problem?
Is there a solution?
I deleted all and installed QGIS 3.10.02, GRASS and SAGA:
QGIS version
3.10.2-A Coruña
QGIS code revision
d4cd3cfe5a <https://github.com/qgis/QGIS/commit/d4cd3cfe5a>
Compiled against Qt
5.11.2
Running against Qt
5.11.2
Compiled against GDAL/OGR
3.0.3
Running against GDAL/OGR
3.0.3
Compiled against GEOS
3.8.0-CAPI-1.13.1
Running against GEOS
3.8.0-CAPI-1.13.1
Compiled against SQLite
3.29.0
Running against SQLite
3.29.0
PostgreSQL Client Version
11.5
SpatiaLite Version
4.3.0
QWT Version
6.1.3
QScintilla2 Version
2.10.8
Compiled against PROJ
6.3.0
Running against PROJ
Rel. 6.3.0, January 1st, 2020
OS Version
Windows 10 (10.0)
Regards
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Helmut Kudrnovsky <hellik  web.de> escreveu no dia domingo, 2/02/2020 à(s)
12:08:
> Valter Albino wrote
> > OK, thanks,
> > It opens but i'm not able to enter.
> > I will erase all and start to install all over again
> > Cumprimentos,
> > Helmut Kudrnovsky <
> > hellik@
> > 10:16:
> >> Valter Albino wrote
> >> > Hi Helmut,
> >> > Thanks for reply.
> >> > Feel embarrassed, since i can't find the file path you mention.
> >> > Tried to install again, but the error remains, starting in the
> >> > installation:
> >> > [image: Capturar.GIF]
> >> > In my portable PC i did the same but didn't give error, so can run
> >> GRASS
> >> > GIS with no problems.
> >> > I didn't change the language
> >> > Cumprimentos,
> >> > Helmut Kudrnovsky <
> >> > hellik@
> >> > 08:48:
> >> >> Valter Albino wrote
> >> >> > Regarding the issue, this message is also important (during
> >> >> instalation):
> >> >> > [image: ScreenHunter_31 Feb. 01 20.04.gif]
> >> >> > Cumprimentos,
> >> >> > ---------- Forwarded message ---------
> >> >> > De: Valter Albino <
> >> >> > valteralbino@
> >> >> > Date: sábado, 1/02/2020 à(s) 19:52
> >> >> > Subject: GRASS GIS problem from OSGeo4W Setup
> >> >> > To: grass-user <
> >> >> > grass-user  .osgeo
> >> >> > Hi
> >> >> > *1)* Trying to install GRASS 7.8.2 or 7.9.dev but have the
> following
> >> >> > message:
> >> >> > OSGeo4W Setup - Running postinstall scripts
> >> >> > Postinstall script errors
> >> >> > These do not necessarly mean that affectes packages will fail to
> >> >> function
> >> >> > properly, but please check /var/log/setup.log.full and report any
> >> >> > problems.
> >> >> > Package: Unknown package
> >> >> >     qgis-common.bat exit code -1073741511
> >> >> > *2)* So, when starting from windows menu, have the follwing
> message:
> >> >> > Starting GRASS GIS...
> >> >> > Error: Reading settings from file
> >> >> > <C:\Users\Particular\AppData\Roaming\GRASS7\wx> failed.
> >> >> >                 Details: not enough values to unpack (expected 2,
> >> got
> >> >> 1)
> >> >> >                 Line: ''
> >> >> > Using 64bits Windows OS, and having this issue from the 1st time,
> >> after
> >> >> > update QGIS and GRASS from OSGeo4W Setup.
> >> >> > Thanks
> >> >> > Cumprimentos,
> >> >> > _______________________________________________
> >> >> > grass-user mailing list
> >> >> > grass-user  .osgeo
> >> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
> >> >> > ScreenHunter_31 Feb. 01 20.04.gif (15K)
> http://osgeo-org.1560.x6.nabble.com/attachment/5428909/0/ScreenHunter_31%20Feb.%2001%2020.04.gif&gt
> >> >> It's part of the OSGeo4W repackaging. Try to reinstall.
> >> >> best regards
> >> >> Helmut
> >> >> Sent from:
> >> http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> >> > grass-user  .osgeo
> >> > grass-user  .osgeo
> >> > Capturar.GIF (140K)
> http://osgeo-org.1560.x6.nabble.com/attachment/5428927/0/Capturar.GIF>
> >> The path is something like
> >> C:\users\yourusername\appdata\...\roaming\grass7
> >> Do a search for grass7 in the appdata subfolder.
> >> Or copy
> >>  %APPDATA%
> >> in the Windows file explorer to open directly the appdata folder.
> >> best regards
> >> Helmut
> >> Sent from:
> > grass-user  .osgeo
> > grass-user  .osgeo
> Looks like a dependencies mismatch:
> https://grasswiki.osgeo.org/wiki/WinGRASS_errors
> Can't reproduce it here in my 64bit OSGeo4W environment
> Try to setup a clean OSGeo4W environment
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user  lists.osgeo.org
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200202/c5f9c2cc/attachment-0001.html>
Type: image/png
Desc: não disponível
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200202/c5f9c2cc/attachment-0001.png>
