[GRASS-user] Example project for a GRASS GIS module on GitHub
    Vaclav Petras
    wenzeslaus at gmail.com
    Tue Feb  4 17:29:26 PST 2020
Zenodo & JOSS in relation to r.example.plus: If you have idea on the text,
please open a PR. I suggest adding it as a subsection of "What is next" and
making the current content of that section a subsection as well.
As for the JOSS and grass-addons repo:
On Tue, Feb 4, 2020 at 8:25 AM Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Hi,
> In this context we should probably also keep JOSS in mind and probably
> make devs aware of that possibility, including linking a JOSS paper to the
> repo. See presentation from FOSSDEM [1] for more background.
> Question is, if it is possible to have the link on a module basis in
> grass-addons.
What do you mean by a link? Does JOSS require the software to be in a
separate repo?
Best,
Vaclav
> Cause, I also think that getting stuff into grass-addons is important for
> the reasons Vaclav lists in the repo.
> Cheers
> Stefan
> 1: https://video.fosdem.org/2020/AW1.126/open_research_joss.webm
> -----Original Message-----
> From: "Peter Löwe" <peter.loewe at gmx.de>
> Sent: tirsdag 4. februar 2020 11:24
> To: grass-user at lists.osgeo.org
> Cc: Stefan Blumentrath <Stefan.Blumentrath at nina.no>; wenzeslaus at gmail.com
> Subject: [GRASS-user] Example project for a GRASS GIS module on GitHub
> Hi Vasek,
> thanks for setting up the demo module on GitHub!
> To demonstrate how module authors can get credit by scientific citation,
> some kind of reference/howto describing how the integration of the GitHub
> project and the Zenodo data repositiory (https://www.zenodo.org/) can be
> achieved, as explained here:
> https://www.zenodo.org/login/?next=%2Faccount%2Fsettings%2Fgithub%2F
> https://guides.github.com/activities/citable-code/
> By doing so, a persistent identifier (DOI) is assigned to the GRASS module
> codebase. Zenodo also offers a handy tool to provide citation strings for
> the modulde code in hundreds of citation styles.
> Best regards,
> Peter
> > From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of
> Vaclav Petras
> > Sent: torsdag 30. januar 2020 02:31
> > To: grass-dev at lists.osgeo.org; GRASS user list <
> grass-user at lists.osgeo.org>
> > Dear users and contributors,
> > I've created an example project (repository) on GitHub. It is a GRASS
> GIS module written in Python which simply adds two raster maps together. It
> uses GitHub Actions to build the module and publish its documentation as a
> website (using GitHub Pages).
> > https://github.com/wenzeslaus/r.example.plus
> > This is based on my earlier work on an example project on GitLab [1] and
> includes several improvements and changes:
> > * There is a test suite included with couple of test functions.
> > * It uses Black for code formatting (assuming author runs it manually).
> > * Repository is marked as a template (see the big "Use this template"
> button).
> > * GitHub Actions are used for:
> >   * compiling the module and running tests,
> >   * checking code quality with Flake8 and Pylint, and
> >   * checking code style with Black.
> > * GitHub Actions are now used for publishing documentation (done by
> GitLab CI before).
> > * Option names now follow GRASS GIS standards more.
> > * More documentation in the code and on how to use the code.
> > * Badges are now in the README file (GitLab had those as project
> properties).
> > Otherwise, I hope the project should describe itself and if something is
> missing or is not documented enough, please open an issue or a pull request.
> > Best,
> > Vaclav
> > PS: We can discuss on grass-dev if this should go under some
> organization and how to improve the "what's next" part [2].
> > [1]
> https://lists.osgeo.org/pipermail/grass-dev/2018-November/090438.html
> > [2] https://github.com/wenzeslaus/r.example.plus#what-is-next
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200204/5de542cc/attachment.html>
