[GRASS-user] Example project for a GRASS GIS module on GitHub
    Stefan Blumentrath
    Stefan.Blumentrath at nina.no
    Tue Feb  4 05:25:08 PST 2020
In this context we should probably also keep JOSS in mind and probably make devs aware of that possibility, including linking a JOSS paper to the repo. See presentation from FOSSDEM [1] for more background.
Question is, if it is possible to have the link on a module basis in grass-addons. Cause, I also think that getting stuff into grass-addons is important for the reasons Vaclav lists in the repo.
Cheers
Stefan
1: https://video.fosdem.org/2020/AW1.126/open_research_joss.webm
-----Original Message-----
Sent: tirsdag 4. februar 2020 11:24
To: grass-user at lists.osgeo.org
Cc: Stefan Blumentrath <Stefan.Blumentrath at nina.no>; wenzeslaus at gmail.com
Subject: [GRASS-user] Example project for a GRASS GIS module on GitHub
Hi Vasek,
thanks for setting up the demo module on GitHub!
To demonstrate how module authors can get credit by scientific citation, some kind of reference/howto describing how the integration of the GitHub project and the Zenodo data repositiory (https://www.zenodo.org/) can be achieved, as explained here: https://www.zenodo.org/login/?next=%2Faccount%2Fsettings%2Fgithub%2F  https://guides.github.com/activities/citable-code/
By doing so, a persistent identifier (DOI) is assigned to the GRASS module codebase. Zenodo also offers a handy tool to provide citation strings for the modulde code in hundreds of citation styles.
Best regards,
Peter
<peter.loewe at gmx.de>
> From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Vaclav Petras
> Sent: torsdag 30. januar 2020 02:31
> To: grass-dev at lists.osgeo.org; GRASS user list <grass-user at lists.osgeo.org>
> Dear users and contributors,
> I've created an example project (repository) on GitHub. It is a GRASS GIS module written in Python which simply adds two raster maps together. It uses GitHub Actions to build the module and publish its documentation as a website (using GitHub Pages).
> https://github.com/wenzeslaus/r.example.plus
> This is based on my earlier work on an example project on GitLab [1] and includes several improvements and changes:
> * There is a test suite included with couple of test functions.
> * It uses Black for code formatting (assuming author runs it manually).
> * Repository is marked as a template (see the big "Use this template" button).
> * GitHub Actions are used for:
>   * compiling the module and running tests,
>   * checking code quality with Flake8 and Pylint, and
>   * checking code style with Black.
> * GitHub Actions are now used for publishing documentation (done by GitLab CI before).
> * Option names now follow GRASS GIS standards more.
> * More documentation in the code and on how to use the code.
> * Badges are now in the README file (GitLab had those as project properties).
> Otherwise, I hope the project should describe itself and if something is missing or is not documented enough, please open an issue or a pull request.
> Best,
> Vaclav
> PS: We can discuss on grass-dev if this should go under some organization and how to improve the "what's next" part [2].
> [1] https://lists.osgeo.org/pipermail/grass-dev/2018-November/090438.html
> [2] https://github.com/wenzeslaus/r.example.plus#what-is-next
