[GRASS-user] Fwd: GRASS GIS problem from OSGeo4W Setup
Valter Albino valteralbino at gmail.com
Wed Feb 5 13:43:54 PST 2020
Hi Helmut,
Same problem.
Will post in QGIS mailing list
Thank you
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Valter Albino <valteralbino  gmail.com> escreveu no dia quarta, 5/02/2020
à(s) 10:43:
> Guten Tag Helmut!
> Later at home will try the clean OSGeo4W uninstall:
> 1º - C:\OSGeo4W64 - selecting uninstalling packages or all of OSGeo4W;
> 2º - C:\OSGeo4W64 - delete file tree;
> 3.º - deleting shortcuts;
> 4.º - C:\ %appdata% or C:\Users...roaming ...;
> 5.º - execut in the CLI>regedit;
> 6.º - install from scratch advanced OSGeoW4.
> Best regards
> Cumprimentos,
> Helmut Kudrnovsky <hellik  web.de> escreveu no dia terça, 4/02/2020 à(s)
> 21:48:
>> Valter Albino wrote
>> > Hi Helmut,
>> > Same problems
>> > See attached pdf file:
>> > https://drive.google.com/open?id=1k-Ki6uIOPunHlRuCDQTesWKtM4HsKbB2
>> in the first error messages:
>> postinstall/qgis-rel-dev.bat
>> postinstall/qgis-common.bat
>> these aren't GRASS GIS issues. these have to be reported in QGIS!
>> wild guess: are you try to use QGIS dev versions and QGIS release versions
>> in OSGeo4W at the same time?
>> that's no good idea as, AFAIK, qgis-dev versions in OSGeo4W are depending
>> on
>> gdal dev versions; a library mixing may be on the way ....
>> tested here on several 64bit win 10 boxes with this combination of regular
>> qgis releases (ltr and latest) and grass gis release and grass gis dailys,
>> all available in OSGeo4W:
>> qgis ltr 3.4.15-1
>> qgis 3.10.2-2
>> grass 7.8.2-1
>> grass 7.9.dev-b98dc112d-90
>> no error so far on about 5 different win 10 boxes.
>> suggestions:
>> delete the OSGeo4W environment completly and set it up freshly with grass
>> gis/qgis combinantions mentioned above. no qgis-dev versions should be
>> activated.
>> if issues with qgis still pop up again, these should be reported there.
>> best regards
>> Helmut
>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>> grass-user mailing list
>> grass-user  lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200205/a5629760/attachment.html>
