[GRASS-user] Fwd: GRASS GIS problem from OSGeo4W Setup
Valter Albino
valteralbino at gmail.com
Wed Feb 5 02:43:33 PST 2020
Guten Tag Helmut!
Later at home will try the clean OSGeo4W uninstall:
1º - C:\OSGeo4W64 - selecting uninstalling packages or all of OSGeo4W;
2º - C:\OSGeo4W64 - delete file tree;
3.º - deleting shortcuts;
4.º - C:\ %appdata% or C:\Users...roaming ...;
5.º - execut in the CLI>regedit;
6.º - install from scratch advanced OSGeoW4.
Best regards
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Helmut Kudrnovsky <hellik web.de> escreveu no dia terça, 4/02/2020 à(s)
21:48:
> Valter Albino wrote
> > Hi Helmut,
> > Same problems
> > See attached pdf file:
> > https://drive.google.com/open?id=1k-Ki6uIOPunHlRuCDQTesWKtM4HsKbB2
> in the first error messages:
> postinstall/qgis-rel-dev.bat
> postinstall/qgis-common.bat
> these aren't GRASS GIS issues. these have to be reported in QGIS!
> wild guess: are you try to use QGIS dev versions and QGIS release versions
> in OSGeo4W at the same time?
> that's no good idea as, AFAIK, qgis-dev versions in OSGeo4W are depending
> on
> gdal dev versions; a library mixing may be on the way ....
> tested here on several 64bit win 10 boxes with this combination of regular
> qgis releases (ltr and latest) and grass gis release and grass gis dailys,
> all available in OSGeo4W:
> qgis ltr 3.4.15-1
> qgis 3.10.2-2
> grass 7.8.2-1
> grass 7.9.dev-b98dc112d-90
> no error so far on about 5 different win 10 boxes.
> suggestions:
> delete the OSGeo4W environment completly and set it up freshly with grass
> gis/qgis combinantions mentioned above. no qgis-dev versions should be
> activated.
> if issues with qgis still pop up again, these should be reported there.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> grass-user lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200205/9181579f/attachment-0001.html>
