[GRASS-user] ESRI formats: gdb and shp
Daniel Victoria daniel.victoria at gmail.com
Tue Feb 11 08:24:43 PST 2020
What do you mean by better? Correct data? Easier to import?
If they contain the same data I think it does not matter which one you use.
Specially because you are talking about point data. But, if there is a
difference in the data, then you have another problem. Figuring out which
one is correct
Cheers
On Tue, Feb 11, 2020 at 1:13 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> I have two files of point locations: sites.gdb and sites.shp. I also have a
> file with (I assume) the same data. Am I correct is assuming that the .gdb
> file would be topographically preferred over the .shp file and the better
> one to import?
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200211/8cce7f1b/attachment.html>
