[GRASS-user] no more gui after upgrade to buster
Frank David
frank.david at geophom.fr
Sat Jan 11 01:52:51 PST 2020
Yes why not. Is the installation procedure is same than stretch ? Is
Python3 support will not make problems with my Python2 scripts ? and
what to do to avoid in that case ?
Do I follow this ? >
https://grasswiki.osgeo.org/wiki/Compile_and_Install#GRASS_7_on_Debian_Stretch
Thank you
Le 10/01/2020 à 21:01, Markus Neteler a écrit :
> Hi,
> any chance that you update to the much more modern GRASS GIS 7.8?
> Best
> Markus
> On Thu, Jan 9, 2020 at 6:05 PM Frank David <frank.david at geophom.fr> wrote:
>> Hello all,
>> I have no more gui on grass 7.6 after upgrade from debian strech to buster.
>> Thank you for your help !
>> Regards
>> Frank
>> See below last errors :
>> Traceback (most recent call last):
>> File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 169, in <module>
>> sys.exit(main())
>> File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 156, in main
>> app = GMApp(workspaceFile)
>> File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 50, in __init__
>> wx.App.__init__(self, False)
>> File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py", line 8628, in __init__
>> self._BootstrapApp()
>> File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py", line 8196, in _BootstrapApp
>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
>> File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 103, in OnInit
>> workspace=self.workspaceFile)
>> File "/usr/local/grass-7.6.0/gui/wxpython/lmgr/frame.py", line 142, in __init__
>> self.notebook = self._createNoteBook()
>> File "/usr/local/grass-7.6.0/gui/wxpython/lmgr/frame.py", line 337, in _createNoteBook
>> gcstyle=GC_PROMPT)
>> File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/goutput.py", line 118, in __init__
>> self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
>> File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/prompt.py", line 139, in __init__
>> GPrompt.__init__(self, parent=parent, menuModel=menuModel)
>> File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/prompt.py", line 57, in __init__
>> self.mapList = self._getListOfMaps()
>> File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/prompt.py", line 101, in _getListOfMaps
>> result['raster'] = grass.list_strings('raster')
>> File "/usr/local/grass-7.6.0/etc/python/grass/script/core.py", line 1252, in list_strings
>> mapset=mapset).splitlines():
>> File "/usr/local/grass-7.6.0/etc/python/grass/script/core.py", line 478, in read_command
>> return handle_errors(returncode, stdout, args, kwargs)
>> File "/usr/local/grass-7.6.0/etc/python/grass/script/core.py", line 334, in handle_errors
>> returncode=returncode)
>> grass.exceptions.CalledModuleError: Module run None ['g.list', '--q', '-m', 'type=raster'] ended with error
>> Process ended with non-zero return code 127. See errors in the (error) output.
>> Error in atexit._run_exitfuncs:
>> File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
>> func(*targs, **kargs)
>> PyAssertionError: C++ assertion "GetEventHandler() == this" failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event handlers must have been removed
>> Error in sys.exitfunc:
>> wx._core.PyAssertionError: C++ assertion "GetEventHandler() == this" failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event handlers must have been removed
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
*Geophom*
327 rue de Vieille Cour 44521 OUDON
Tel +33(0)2 85 52 02 59 - Port +33(0)6 04 47 91 06
www.geophom.fr
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200111/b9a749a4/attachment.html>
