[GRASS-user] no more gui after upgrade to buster
Markus Neteler
neteler at osgeo.org
Fri Jan 10 12:01:27 PST 2020
any chance that you update to the much more modern GRASS GIS 7.8?
Best
Markus
On Thu, Jan 9, 2020 at 6:05 PM Frank David <frank.david at geophom.fr> wrote:
> Hello all,
> I have no more gui on grass 7.6 after upgrade from debian strech to buster.
> Thank you for your help !
> Regards
> Frank
> See below last errors :
> Traceback (most recent call last):
> File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 169, in <module>
> sys.exit(main())
> File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 156, in main
> app = GMApp(workspaceFile)
> File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 50, in __init__
> wx.App.__init__(self, False)
> File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py", line 8628, in __init__
> self._BootstrapApp()
> File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py", line 8196, in _BootstrapApp
> return _core_.PyApp__BootstrapApp(*args, **kwargs)
> File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 103, in OnInit
> workspace=self.workspaceFile)
> File "/usr/local/grass-7.6.0/gui/wxpython/lmgr/frame.py", line 142, in __init__
> self.notebook = self._createNoteBook()
> File "/usr/local/grass-7.6.0/gui/wxpython/lmgr/frame.py", line 337, in _createNoteBook
> gcstyle=GC_PROMPT)
> File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/goutput.py", line 118, in __init__
> self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
> File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/prompt.py", line 139, in __init__
> GPrompt.__init__(self, parent=parent, menuModel=menuModel)
> File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/prompt.py", line 57, in __init__
> self.mapList = self._getListOfMaps()
> File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/prompt.py", line 101, in _getListOfMaps
> result['raster'] = grass.list_strings('raster')
> File "/usr/local/grass-7.6.0/etc/python/grass/script/core.py", line 1252, in list_strings
> mapset=mapset).splitlines():
> File "/usr/local/grass-7.6.0/etc/python/grass/script/core.py", line 478, in read_command
> return handle_errors(returncode, stdout, args, kwargs)
> File "/usr/local/grass-7.6.0/etc/python/grass/script/core.py", line 334, in handle_errors
> returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None ['g.list', '--q', '-m', 'type=raster'] ended with error
> Process ended with non-zero return code 127. See errors in the (error) output.
> Error in atexit._run_exitfuncs:
> File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
> func(*targs, **kargs)
> PyAssertionError: C++ assertion "GetEventHandler() == this" failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event handlers must have been removed
> Error in sys.exitfunc:
> wx._core.PyAssertionError: C++ assertion "GetEventHandler() == this" failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event handlers must have been removed
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
