[GRASS-user] no more gui after upgrade to buster
Frank David frank.david at geophom.fr
Thu Jan 9 07:48:39 PST 2020
Hello all,
I have no more gui on grass 7.6 after upgrade from debian strech to buster.
Thank you for your help !
Regards
Frank
See below last errors :
   File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 169, in
<module>
     sys.exit(main())
   File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 156, in main
     app = GMApp(workspaceFile)
   File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 50, in __init__
     wx.App.__init__(self, False)
   File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py", line
8628, in __init__
     self._BootstrapApp()
8196, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
   File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 103, in OnInit
     workspace=self.workspaceFile)
   File "/usr/local/grass-7.6.0/gui/wxpython/lmgr/frame.py", line 142,
in __init__
     self.notebook = self._createNoteBook()
   File "/usr/local/grass-7.6.0/gui/wxpython/lmgr/frame.py", line 337,
in _createNoteBook
     gcstyle=GC_PROMPT)
   File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/goutput.py", line
118, in __init__
     self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
   File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/prompt.py", line
139, in __init__
     GPrompt.__init__(self, parent=parent, menuModel=menuModel)
57, in __init__
     self.mapList = self._getListOfMaps()
101, in _getListOfMaps
     result['raster'] = grass.list_strings('raster')
   File "/usr/local/grass-7.6.0/etc/python/grass/script/core.py", line
1252, in list_strings
     mapset=mapset).splitlines():
478, in read_command
     return handle_errors(returncode, stdout, args, kwargs)
334, in handle_errors
     returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.list', '--q',
'-m', 'type=raster'] ended with error
Process ended with non-zero return code 127. See errors in the (error)
output.
Error in atexit._run_exitfuncs:
   File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
     func(*targs, **kargs)
PyAssertionError: C++ assertion "GetEventHandler() == this" failed at
../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event
handlers must have been removed
Error in sys.exitfunc:
wx._core.PyAssertionError: C++ assertion "GetEventHandler() == this"
failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed
event handlers must have been removed
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200109/c7d258c9/attachment-0001.html>
