[GRASS-user] r.in.lidar / v.in.lidar missing in Ubnutu 18.04 package
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Tue Jan 14 02:22:06 PST 2020
Good point. Yes, indeed it is built without liblas support (see: https://launchpadlibrarian.net/455539996/buildlog_ubuntu-bionic-amd64.grass_7.8.2-1~bionic1_BUILDING.txt.gz and search for dh_auto_configure).
Will open a ticket...
-----Original Message-----
Sent: mandag 13. januar 2020 15:57
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Cc: grass-user grass-user <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] r.in.lidar / v.in.lidar missing in Ubnutu 18.04 package
Hi Stefan,
On Mon, Jan 13, 2020 at 1:28 PM Stefan Blumentrath <Stefan.Blumentrath at nina.no> wrote:
> Hi Markus,
> And thanks for your reply.
> On the one box I also have self-compiled GRASS GIS 7.9. And for that r.in.lidar works fine.
> I also added more liblas related packages. But that did not help with GRASS 7.8.2...
Do you mean a self-compiled GRASS 7.8.2? Or the Ubuntu package?
> So I am not sure if this is a packaging issue with liblas. If liblas works for self-compiled GRASS 7.9, shouldn`t it work with 7.8.2 as well.
> In order to double check, I downloaded the grass-core package manually, and it does not seem to contain r.in.lidar (at least I could not find it)...
> Thus, I guess it is an issue with the grass-core package, no?
... of Ubuntu, right?
You may want to compare the build scripts used there, perhaps in one liblas is simply not enabled.
Best
Markus
