[GRASS-user] r.in.lidar / v.in.lidar missing in Ubnutu 18.04 package
Markus Neteler
neteler at osgeo.org
Mon Jan 13 06:56:32 PST 2020
Hi Stefan,
On Mon, Jan 13, 2020 at 1:28 PM Stefan Blumentrath
<Stefan.Blumentrath at nina.no> wrote:
> Hi Markus,
> And thanks for your reply.
> On the one box I also have self-compiled GRASS GIS 7.9. And for that r.in.lidar works fine.
> I also added more liblas related packages. But that did not help with GRASS 7.8.2...
Do you mean a self-compiled GRASS 7.8.2? Or the Ubuntu package?
> So I am not sure if this is a packaging issue with liblas. If liblas works for self-compiled GRASS 7.9, shouldn`t it work with 7.8.2 as well.
> In order to double check, I downloaded the grass-core package manually, and it does not seem to contain r.in.lidar (at least I could not find it)...
> Thus, I guess it is an issue with the grass-core package, no?
... of Ubuntu, right?
You may want to compare the build scripts used there, perhaps in one
liblas is simply not enabled.
Best
Markus
