[GRASS-user] r.in.lidar / v.in.lidar missing in Ubnutu 18.04 package
Stefan Blumentrath Stefan.Blumentrath at nina.no
Mon Jan 13 04:27:53 PST 2020
Hi Markus,
And thanks for your reply.
On the one box I also have self-compiled GRASS GIS 7.9. And for that r.in.lidar works fine.
I also added more liblas related packages. But that did not help with GRASS 7.8.2...
So I am not sure if this is a packaging issue with liblas. If liblas works for self-compiled GRASS 7.9, shouldn`t it work with 7.8.2 as well.
In order to double check, I downloaded the grass-core package manually, and it does not seem to contain r.in.lidar (at least I could not find it)...
Thus, I guess it is an issue with the grass-core package, no?
Cheers
Stefan
-----Original Message-----
Sent: fredag 10. januar 2020 21:16
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Cc: grass-user grass-user <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] r.in.lidar / v.in.lidar missing in Ubnutu 18.04 package
On Thu, Jan 9, 2020 at 9:35 AM Stefan Blumentrath <Stefan.Blumentrath at nina.no> wrote:
> Hi,
> On two different Ubuntu (18.04) installations with packages from
> ubuntugis-unstable (GRASS GIS 7.8.2), I am missing
> r.in.lidar/v.in.lidar modules. Neither GRASS nor a OS search finds
> r.in.lidar/v.in.lidar…
> I double-checked and liblas and pdal are installed on both of boxes.
So far it requires on liblas.
For PDAL support, see
- https://github.com/OSGeo/grass/pull/61 (still work in progress)
- addon: https://github.com/OSGeo/grass-addons/tree/master/grass7/raster/r.in.pdal
> Is this a packaging issue or is a specific order of installation required for r.in.lidar / v.in.lidar to become available.
I guess a packaging error with liblas on Ubuntu.
Markus
