[GRASS-user] r.proj ERROR
nik n.hafner at carto.at
Sun Jan 12 00:24:03 PST 2020
Hi
> which GRASS version and operating system are you using?
I also use:
GRASS Version: 7.8.2
Code revision: 3900fb114
Build date: 2019-12-11
Build platform: x86_64-w64-mingw32
GDAL: 3.0.2
PROJ: 6.2.1
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
I still get this message:
r.proj location=MGI2wgs84_Austria_Lambert mapset=PERMANENT
input=dhm_10m_ogd_austria output=dhm_10m_ogd_dachstein_NEU method=bilinear
resolution=10
ERROR: Unable to open element file <> for <WIND at dachstein>
and I tested it from an other location too but its the same problem:
r.proj location=ASTER_lat-long mapset=PERMANENT
input=DHM_SRTM30m_Aut-plus-Umgebung output=dhm_30m_ASTER_dachstein
method=bilinear resolution=30
What can be wrong?
Nik
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
