[GRASS-user] r.proj ERROR
Helmut Kudrnovsky hellik at web.de
Sun Jan 12 06:26:04 PST 2020
nik wrote
> Hi
>> which GRASS version and operating system are you using?
> I also use:
> GRASS Version: 7.8.2
> Code revision: 3900fb114
> Build date: 2019-12-11
> Build platform: x86_64-w64-mingw32
> GDAL: 3.0.2
> PROJ: 6.2.1
> GEOS: 3.8.0
> SQLite: 3.29.0
> Python: 3.7.0
> wxPython: 4.0.7
> Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
> I still get this message:
> r.proj location=MGI2wgs84_Austria_Lambert mapset=PERMANENT
> input=dhm_10m_ogd_austria output=dhm_10m_ogd_dachstein_NEU method=bilinear
> resolution=10
> ERROR: Unable to open element file <> for <WIND at dachstein>
> and I tested it from an other location too but its the same problem:
> r.proj location=ASTER_lat-long mapset=PERMANENT
> input=DHM_SRTM30m_Aut-plus-Umgebung output=dhm_30m_ASTER_dachstein
> method=bilinear resolution=30
> What can be wrong?
> Nik
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user
What does r.proj -g output? With PROJ: 6.2.1,  a proj pipeline has to be
given in r.proj. it's not in your cmd
Can you report all steps with  g.proj, g.region,, r.proj in source and
target locations as I've done?
best regards
Helmut
