[GRASS-user] i.sentinel.import imports empty maps
Valter Albino
valteralbino at gmail.com
Wed Jan 29 06:59:47 PST 2020
Same issue!
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Veronica Andreo <veroandreo gmail.com> escreveu no dia quarta, 29/01/2020
à(s) 14:31:
> Suspicion confirmed, this was a map imported with i.sentinel.import in
> latlong location. It forces a resolution of 20 degrees, instead of the
> equivalent of 20m in degrees
> GRASS 7.9.dev (latlong_wgs84):~ > r.info T21JYM_20200126T134201_B11_20m
> | Map: T21JYM_20200126T134201_B11_20 Date: Wed Jan 29 11:09:18 2020
> | Mapset: sentinel2 Login of Creator: vandreo
> | Location: latlong_wgs84
> | DataBase: /home/vandreo/grassdata
> | Title:
> | Timestamp: 26 Jan 2020 13:49:32.751425
> | Type of Map: raster Number of Categories: 0
> | Data Type: FCELL
> | Rows: 1
> | Columns: 1
> | Total Cells: 1
> | Projection: Latitud - Longitud.
> | N: 20S S: 40S Res: 20
> | E: 40W W: 60W Res: 20
> | Range of data: min = NULL max = NULL
> | Data Description:
> | generado por r.proj
> | Comments:
> | r.proj --quiet location="temp_import_location_97485"
> mapset="PERMANE\ |
> | NT" input="T21JYM_20200126T134201_B11_20m" method="bilinear"
> memory=\ |
> | 500 resolution=20.0
> El mié., 29 ene. 2020 a las 11:20, Veronica Andreo (<veroandreo gmail.com>)
> escribió:
>> Hi all,
>> I'm using i.sentinel.import with -r flag to import sentinel scenes into a
>> latlong location. No matter if I use, extent=region or extent=input, I get
>> empty maps imported.
>> Estimated target resolution for input band
>> <T21JYM_20200126T134201_B8A_20m>: 0.00018570053194443554
>> Using given resolution for input band <T21JYM_20200126T134201_B8A_20m>:
>> 20.0
>> Reprojecting <T21JYM_20200126T134201_B8A_20m>...
>> ERROR: The reprojected raster <T21JYM_20200126T134201_B8A_20m> is empty
>> Meanwhile a normal r.import with input and output, imports the map
>> properly. Is it possible that i.sentinel.import tries to set a 20
>> resolution also in a lat long location???That would be degrees then, and
>> hence the empty maps...
>> BTW, I noted that grass-addons repo does not have the issues activated.
>> With trac closed for new tickets, I think it is necessary to activate
>> issues in grass-addons too
>> Thanks much in advance
>> Vero
> grass-user mailing list
> grass-user lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200129/22e03be5/attachment-0001.html>
