[GRASS-user] i.sentinel.import imports empty maps
Veronica Andreo
veroandreo at gmail.com
Wed Jan 29 06:30:48 PST 2020
Suspicion confirmed, this was a map imported with i.sentinel.import in
latlong location. It forces a resolution of 20 degrees, instead of the
equivalent of 20m in degrees
GRASS 7.9.dev (latlong_wgs84):~ > r.info T21JYM_20200126T134201_B11_20m
| Map: T21JYM_20200126T134201_B11_20 Date: Wed Jan 29 11:09:18 2020
| Mapset: sentinel2 Login of Creator: vandreo
| DataBase: /home/vandreo/grassdata
| Title:
| Timestamp: 26 Jan 2020 13:49:32.751425
| Type of Map: raster Number of Categories: 0
| Data Type: FCELL
| Rows: 1
| Columns: 1
| Total Cells: 1
| Projection: Latitud - Longitud.
| N: 20S S: 40S Res: 20
| E: 40W W: 60W Res: 20
| Range of data: min = NULL max = NULL
| Data Description:
| generado por r.proj
| Comments:
| r.proj --quiet location="temp_import_location_97485" mapset="PERMANE\
| NT" input="T21JYM_20200126T134201_B11_20m" method="bilinear" memory=\
| 500 resolution=20.0
El mié., 29 ene. 2020 a las 11:20, Veronica Andreo (<veroandreo at gmail.com>)
escribió:
> Hi all,
> I'm using i.sentinel.import with -r flag to import sentinel scenes into a
> latlong location. No matter if I use, extent=region or extent=input, I get
> empty maps imported.
> Estimated target resolution for input band
> <T21JYM_20200126T134201_B8A_20m>: 0.00018570053194443554
> Using given resolution for input band <T21JYM_20200126T134201_B8A_20m>:
> 20.0
> Reprojecting <T21JYM_20200126T134201_B8A_20m>...
> ERROR: The reprojected raster <T21JYM_20200126T134201_B8A_20m> is empty
> Meanwhile a normal r.import with input and output, imports the map
> properly. Is it possible that i.sentinel.import tries to set a 20
> resolution also in a lat long location???That would be degrees then, and
> hence the empty maps...
> BTW, I noted that grass-addons repo does not have the issues activated.
> With trac closed for new tickets, I think it is necessary to activate
> issues in grass-addons too
> Thanks much in advance
> Vero
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200129/dbb65d28/attachment.html>
