[GRASS-user] Issue when installing r.zonal.classes with g.extension
Veronica Andreo veroandreo at gmail.com
Thu Jan 30 03:46:53 PST 2020
Hi Tais,
What grass version are you using? and which operating system? Does the same
happen with other add-ons?
In my Fedora box, it goes fine, but there was a problem with grass76 in
windows that started when we migrated to github. AFAIK, this was solved in
grass78. So, if you have an old grass, please update :)
HTH,
Vero
El jue., 30 ene. 2020 a las 7:18, Taïs (<tgrippa at ulb.ac.be>) escribió:
> Hi all,
> I'm facing an issue when trying to install the addon r.zonal.classes.
> When executing "g.extension -l" the addon is well listed as available,
> but when I try to install it using "g.extension r.zonal.classes",
> g.extension say it don't find it:
> Fetching <r.zonal.classes> from GRASS GIS Addons repository (be patient)...
> ERROR: Extension <r.zonal.classes> not found
> I checked on the compilation log of Linux add-on and it's a green light
> (https://grass.osgeo.org/addons/grass7/logs/)
> Does someone have any idea ?
> Best,
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200130/88286040/attachment.html>
