[GRASS-user] Issue when installing r.zonal.classes with g.extension
Taïs
tgrippa at ulb.ac.be
Fri Jan 31 00:46:56 PST 2020
Hi Vero,
Indeed, you are right. After upgrading to 7.8 it works perfectly !!
Thanks a lot
Le 30/01/20 à 12:46, Veronica Andreo a écrit :
> Hi Tais,
> What grass version are you using? and which operating system? Does the
> same happen with other add-ons?
> In my Fedora box, it goes fine, but there was a problem with grass76
> in windows that started when we migrated to github. AFAIK, this was
> solved in grass78. So, if you have an old grass, please update :)
> HTH,
> Vero
> El jue., 30 ene. 2020 a las 7:18, Taïs (<tgrippa at ulb.ac.be
> <mailto:tgrippa at ulb.ac.be>>) escribió:
> Hi all,
> I'm facing an issue when trying to install the addon r.zonal.classes.
> When executing "g.extension -l" the addon is well listed as
> available,
> but when I try to install it using "g.extension r.zonal.classes",
> g.extension say it don't find it:
> Fetching <r.zonal.classes> from GRASS GIS Addons repository (be
> patient)...
> ERROR: Extension <r.zonal.classes> not found
> I checked on the compilation log of Linux add-on and it's a green
> light
> (https://grass.osgeo.org/addons/grass7/logs/)
> Does someone have any idea ?
> Best,
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200131/ab66d070/attachment.html>
Une pièce jointe autre que texte a été nettoyée...
Nom: tgrippa.vcf
Type: text/x-vcard
Taille: 4 octets
Desc: non disponible
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200131/ab66d070/attachment.vcf>
