[GRASS-user] Import Shape Files
Markus Neteler neteler at osgeo.org
Wed Jul 1 09:23:50 PDT 2020
Hi Martin,
On Wed, Jul 1, 2020 at 4:29 PM Martin Bittens <martin.bittens at gmx.de> wrote:
> I don't know why this happened but obviously GRASS provides different
> metadata for the same shape-file depending on the command you are using.
To analyse this in depth access to the dataset would be required (even
an excerpt as a reproducible example will do, i.e. one extracted
polygon or whatever is in your dataset).
Without that I would not know how to find out...
Regards,
Markus
