[GRASS-user] Import Shape Files
Martin Bittens
martin.bittens at gmx.de
Thu Jul 2 04:57:46 PDT 2020
Hello Markus,
ok, let us try.
Attached I send (as zip files):
1.) QGIS_LT_AOI_3.zip with a shape layer created in QGIS 2.14.0. It
contains contains 5 sample points extracted from an existing site (EPSG
31983);
2.) Test_SG.zip with the files from the grassdata directory created by
GRASS 7.8.3 after establishing the location "Test_SG" (EPSG 31983) and
importing the shape layer into "Test_SG".
Regards
Martin
Am 7/1/2020 um 1:23 PM schrieb Markus Neteler:
> Hi Martin,
> On Wed, Jul 1, 2020 at 4:29 PM Martin Bittens <martin.bittens at gmx.de> wrote:
>> I don't know why this happened but obviously GRASS provides different
>> metadata for the same shape-file depending on the command you are using.
> To analyse this in depth access to the dataset would be required (even
> an excerpt as a reproducible example will do, i.e. one extracted
> polygon or whatever is in your dataset).
> Without that I would not know how to find out...
> Regards,
> Markus
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200702/8bf84719/attachment-0002.bin>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200702/8bf84719/attachment-0003.bin>
